Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 08-23-2013 | 03:45 AM
  #13906
sickpuppy1's Avatar
Yep, the Jconcepts foams in mine lasted for a few weeks also ,while the AKA were good enough to use in a second set of tires if need be. Weird.
sickpuppy1 is offline
Old 08-23-2013 | 04:41 AM
  #13907
Graham11's Avatar
Hey guys, meant to post about this a while ago but on eBay there is a seller by the name mikeys-rc-shop who auctions off SCT410 parts but does it from kits so instead of having to buy all pieces separately at 10X the price, you can get awesome deals, for example I got the entire stearing bell crank section for $2.26 and got front cvds and a full set of camber links for $1.29 and the full front bumper, arms, diff case and braces for $12... I could go on and on... oh and an entire front diff for $32. And he always has the auctions running so if you dont get a good price the first time you can try again. I have bought like 80% of the parts for a second kit for like $170. Anyway, im talking to him about giving me a code for you guys in rctech to get free/discounted shipping or some other deal.
Just a neighborly heads up(just dont drive the bids up on me haha)... I asked him to start doing for EB48 too!
Graham11 is offline
Old 08-23-2013 | 06:17 AM
  #13908
Hoese37's Avatar
Originally Posted by wreckya
I've been gluing up tires while waiting for parts and upgrades to come in, so in the beginning of this thread guys were saying that JConcept inserts don't last and they all take em out and replace with AKA and Proline inserts? Is this true, have a pair of pressure points I'm about to glue up.
I used the JC Profiled foam in mine, theyre ok. I will never use proline foam agian tho, I have 2 sets that both have flat spots even tho I never store them on the truck or standing up.
So does the RX8 Gen2 servo wire reach the receiver box or will I need an extension? My RX8 is on its way starting build tomorrow. Also is anyone running a futaba servo, if so is its wire reaching the receiver box? I like a clean truck and wire job hate using extensions.
My RX8 was fine, the XP DS1015 servo was about 2" too short.
Hoese37 is offline
Old 08-23-2013 | 07:08 AM
  #13909
Bernard_Jr's Avatar
Default Straight Cut Gears
Finished a .2 build yesterday and ran it down the street a little. If this is any indication, I can't wait to try the new gears and rear housing in the SCT. It just seems quieter.
Anybody made the change yet?
Bernard_Jr is offline
Old 08-23-2013 | 07:45 AM
  #13910
Graham11's Avatar
the SCT410 has the new internal gears stock already but not the new straight cut spur and pinion gears and the new angled rear housing.
Graham11 is offline
Old 08-23-2013 | 07:56 AM
  #13911
HickamHatch's Avatar
I drove my truck yesterday. Everything was good until it landed off a jump on the front right tire and broke the 17mm PLASTIC adapter. These things are not that strong. I will probably switch back over to 12mm.
HickamHatch is offline
Old 08-23-2013 | 08:24 AM
  #13912
fq06's Avatar
Haven't driven mine yet with the 17mm hex but I may grab another pack and send one to a machinist buddy and have him make a few. Those are regular offset right? Not +1mm? I may have him add a little to them to get it out to max width if they are +0.
I really don't want to go back to 12mm hex, feel like I'm taking a step backwards on the evolution chart and hunching over a bit
fq06 is offline
Old 08-23-2013 | 08:40 AM
  #13913
Bernard_Jr's Avatar
That's what I was referring to. I got the straight cut gears in earlier this week but decided to wait for the new rear diff case to show up today before I tore it apart.
I could only fit one shim in the new diff case by the way. It really felt super smooth in the EB.
Old 08-23-2013 | 08:57 AM
  #13914
Graham11's Avatar
So you would recommend the new straight cut spur and pinion I guess? Been trying to decide if I should buy now or wait til my current originals wear out. Same with my eb48, do I upgrade all parts to .2 now or just wait til they wear because none of them are going to make a drastic performance difference.
Graham11 is offline
Old 08-23-2013 | 09:05 AM
  #13915
Hoese37's Avatar
Straight cuts gears will free up the drivetrain a bit, mostly off power. Also makes gear lash adjustment more critical.
Hoese37 is offline
Old 08-23-2013 | 09:55 AM
  #13916
1 shim here as well, on the gear side. Whole lot better gear mesh than the front with two shims on the gear side. Only complaint I have with build so far is no axle bearing crush sleeves. Wheel is being tightened up and loading cross pin in axle instead of loading axle through outer bearing inner race and crush sleeve.
JLinney is offline
Old 08-23-2013 | 10:00 AM
  #13917
SMR 510RR's Avatar
Since there is a small amount of play in the axle I dont see how a crush sleeve would do anything, only 1 bearing is getting loaded at a time anyways depending on what direction you are turning.
SMR 510RR is offline
Old 08-23-2013 | 10:16 AM
  #13918
XRated SCT's Avatar
Shock collars are super tight, I suppose these loosen up or..,
XRated SCT is offline
Old 08-23-2013 | 10:31 AM
  #13919
Hoese37's Avatar
I had three that were ok, one was really tight. The collars are made from plastic, so its very east to cross thread them. Get the alum ones. I found a set from my old AE RC8 that worked just fine.
Hoese37 is offline
Old 08-23-2013 | 10:40 AM
  #13920
Bernard_Jr's Avatar
Hopefully I can get some footage this sunday to compare a before and after. I have video that you can clearly here it as it is now.
