Tekno SCT410 Thread
For someone that wants to mount their ESC with screws running up through whatever the ESC is sitting on.
I don't know anyone that mounts their ESC that way. Shoegoo or pick your flavor of servo tape is the most common way to keep the ESC where you want it.
The ESC comes with the screws.
Edit:
Could also be used for unicorn blood filing as well, you don't want to run dry on that one
Edit:
Using Pegasus blood is completely legal.
Edit:
Edit:
I've never bothered with the screws but surprised they are not a good fit. Maybe Tekin never thought anyone would ever try using them
To spend the big $$, but said to be the best, Kyosho zeal tape.
Or the clear 3m tape.
I use shoegoo, it will not come off till you want it to and it leaves no residue. I've ran my RX8 in multiple chassis for well over a year with shoegoo and have not had an issue.
Im not sure that a small rip would be that bad, are you sure you had the spur seated flush on the diff case? Like i said you may have just over filled, my first time out a little came out and looked like a spider web on the white composite spur but it was just extra. ive rebuilt it many times since and havent had an issue.
Did you do like I suggested and clean it all off and go for another run?
I have some tekno 8x1.4 that I have not ran yet. Now I have kyosho 8x1.2 in my sct410 and xray 8x1.2 in my eb48.2. The kyosho's do feel like they have less pack then the xray pistions and the AE pistons that a buddy is using in his sct410. I am going to try the xray pistons in my sct410 soon.
Now, I just cut about 1/4" to 3/8" wide strips and go along the outside edges of the esc. I've never had one fall off!
Just make sure you're cleaning the bottom of the esc, and whatever you're sticking the esc to, very well. I use either rubbing alcohol or denatured alcohol to clean the bottom of the esc and esc tray.
Anyone have a good set up for a small tight indoor dirt track we use ss barcodes.im running the stock set up right now and I can not get the truck to rotate in the turns.my diff fluid is 10/7/5
Yep, I see exactly what you're talking (typing) about!!!
Once again, thanks for your help guys!
**This thread is the absolute best thread on RCTech! I've asked some of the worst noob questions and I have not had one negative thing said to me!! Everyone has been very helpful!**
Trick is to wipe down both surfaces with rubbing alcohol prior to mounting.
I like the 3M tape with the red backing and dark grey tap/foam. They make an extreme and an outdoor version now, not sure which is the kind i'm currently using. I just ordered some of the extreme to see how it goes. Outdoor may have been the better choice assuming it's meant to stand up to water, dirt, etc.
Yep , 3m outdoor tape is awesome ! Just double it up and its as good as the Parma clear or the Kyosho zeal tape .....
17Likes
