Tekno SCT410 Thread
Same here, run the Kyo Orange fronts and green rears (between orange and yellow)
I am thinking of running greens all around on mine
I'm gonna try orange kyosho springs front and rear had light blues. I also went to a 2.2 front sway bar and 2.3 rear sway bar. I run on a small indoor dirt track.
Do the new delrin shock shaft guides work with the original lower shock caps or do I need the updated caps?
Depending on the track, for indoors medium-high bite running 27.5wt Losi oil in rear and this past weekend at a big 1/8 track that was rough, I was running 30wt Losi in the rear, but I'm also running the 8x1.3 pistons as well.
@Kuya_Kimo I also have a set of the Kyo Orange springs for the Front and like them as well. For the most parts I've been using the Kyo Orange fronts or the HB Gray Fronts
Tech Legend
for sway bars, what have you guys found when running a stiffer rear versus front as far as the performance difference than the other way around?
Pretty much using stiffer front here than rear and it feels good, but curious what others are seeing.
Cain I flipped the stock ones end to end
Took my truck apart the other day and the can on my 4300HD had a flat spot on the bottom end of it from hitting the chassis, anyone else have this happen?
I replaced the front & rear A arms on my truck and the ones I replaced them with move back and forth between the hinge pin. There is like 2mm worth of slop? Guess I just got a shitty set of molded A arms, but I hate that I can move them back and forth like that.
Maybe check your pills. On my truck I have seen where the pills wear (especially the rear pills) allowing a lot of slop in the arms. I found that I have to replace the pills much more often than the arms.
has any one try the 2.6mm sway bar on front and rear like the truggy got
Pills are new and it's just the front arms, you can slide the arm back and forth between the hinge pins because the arm is actually not wide enough. The hinge pin hole on the arm has a raised circle around it and there's just not enough material there so there is room for it to slide back and forth instead of being snug up against the pill. I wonder if Tekno would replace them they are brand new?
