Tekno SCT410 Thread
Since the LRC brace says +1 toe it is simply .5 less than the eb48 +1.5 brace correct? So I just subtract -.5 from the toe on the lrc conversion chart that is on the eb48 forums
I'm running on a small indoor track 14 pinion/stock spur 4300 HD tekin w/ rx8 motor is getting to 150 speedo was at 170.anyone getting high temps on the 4300 HD on tight track?
So remove timing, install fan and make sure it is spinning and pointing the correct way, reduce wheel spin by finger or decreasing current limiter and check after a 5 min heat and reply. My temps are ESC 140, motor 150-155 after 5 min but I have had much higher. Your pinion sounds pretty close
Need some help on spring choice I've looked over the first page on rates and all that very helpful BTW!! I see everyone saying get stiffer springs to fix the bucking issue but not sure what I should get. I'm running the rear yellow tekno springs now. Was gonna go red but don't see them on tower hobbies. Any help would be appreciated on what to get.
Question for those with the part. Does the LCG motor mount insert slam the motor against the chassis or is there still a little bit of room? I want to know because I have a 3656SD motor, the fins on the can make it a hair wider then 36mm diameter. But the part says 36mm only. I really wanted to give it a try and see how it does for 20 bucks...
Worth the $20 in my opinion. Also, at least for me, the LCG mount slide in and out much easier than the stock one which i needed to pry even after the two screws were removed.
I run the LCG motor mount with the 3656SD motor and it definitely fits. the amount of clearance depends on the size of the pinion (larger pinion forces motor further away and up the mount), but i am able to run a 13T (or larger pinions) and still have clearance.
Managed to eak out a 33.05second (almost a record for the SC class at this track) lap at the local outdoor track this past weekend and was trying to find ways to stabilize the truck a bit more in the corners . I ordered the mount along with lightened cups/outdrives and some different pistons. (8x1.3). Need to fix my nose dives on the big double table top, it's the only jump I nose on but it's annoying when it happens. I have to hit that jump at a super specific speed and angle to go straight. I heard it's solved with stiffer rear springs, but the truck came with yellows, which should be stiff enough.
Actually the Tekno Red (2.93) spring for the rear or any other springs at the 2.9 spring rate seem to help a lot. I run the Kyo Yellow spring (2.95) since when I bought them a while back the reds where out of stock.
i've been thinking about using these stiffer springs. what shock oils have you been using with red rears?
The Kyosho yellow spring is great on the SCT410. I own way too many springs and keep falling back to these with Orange in the front.
@Kuya_Kimo I also have a set of the Kyo Orange springs for the Front and like them as well. For the most parts I've been using the Kyo Orange fronts or the HB Gray Fronts
