Xray XB4 thread
Yeah you can get longer 75mm bones for $23 each, but I have not found the adjustable axles in the USA. They are not listed on RCamerica's site. I have found a few places in Europe that ship worldwide but that is it. I guess I should have realized when a brand says they are the "Luxury Brand" that means you are going to spend every time you want to make an adjustment.
How is the outer cvd pin captured on the XB4? If it’s retained by the inner bearing in the hub, the B6.1 stub axle may work. I can get some dimensions if you guys think it’ll work.
Zipperfoot, there are another set of pills in the rear hubs. The outward adjustment at the inner pivot can be offset by an adjustment at the hub pill. I realize this deviates from Ty’s setup, but it does give you access to the wider pivot adjustment.
What are people using for front shock tower guards for carpet?
2020 setup sheets available anywhere? Hard pack dusty running a centre diff, tracks rough will be running 6.5,20/81. starting build next week hopefully.
Cheers heaps guys.
Burty
Cheers heaps guys.
Burty
Just picked up my first Xray, a used 2015 with some 2016 parts and starting to learn more about the chassis. How significant -generally- are changes year to year? Based on the old website pages it seems like there's a lot of tweaks but it's hard for me to understand what might be a change to a part that makes it unusable for an older chassis. Also are there certain years where the update was more significant than others?
Want to buy aluminum uprights xra323355
I'm looking for a pair of aluminum uprights for 2019 and newer xb4, xb2, xt2, xt4. The xray part number is xra323355. All of the online sites are out of stock so any info will be helpful. Thanks.
19 Xb4 here. Are there posts to run a LCG battery or what are you guys doing for that? I would prefer not to tape the battery in.
hi guys, just building my 2020 and was wondering if someone could have a look at theres for me and let me know if there the same, the front rear lower suspension holder hasnt got the right depth countersunk screw holes, the screws dont sit in the holder flush like the front suspension holder or any that ive done before. Could someone have a look and tell me if theres is the same?
Part number is 362322.
Cheers heaps
Burty.
Cheers heaps
Burty.
Can anyone comment on the 20 vs the 19 on carpet? Had an 18 that I sold and I'm getting ansty waiting on the 20, I may just pull the trigger on a new 19 at a steep discount soon.
The 18 was so good and not a lot changed on the 19...I can't imagine the 20 is a huge change
