Xray XB4 thread
Will the 2017 xb4 chassis side guards work with the 2018 chassis, alu central bulkhead “low” and alu motor bulkhead “low”?
The pistons also have a larger OD.
Honestly didn't even realize that, thanks! Makes sense as they come off of the same mold. Tack on the reduced blow-by to the tighter cartridge and it all adds up to the much lighter oils most are using this year.
good run this weekend bryan..
Thanks for a great racing program! First time racing on turf, switched the car over after racing in Phoenix the previous weekend and the XB4 was lights out. Just need a couple more practice days to get the hang of the surface and maybe a little bit of ESC tuning.
i was hoping i would get to focus on racing this weekend.. rather than running the races.. and that didnt work out..
They should fit fine as long as there the xray pistons. I found the schelle/vrp pistons to fit much tighter inside the shock body then the 16/17 xray kit pistons. I believe xray has just made the 18 car's pistons a little larger in diameter to fit tighter inside the shock body. Since the schelle/vrp pistons are machined and not molded they are more precise and fit better.
Unfortunately no, because 2018 side guards have a vent for lower motor position. I am in the same boat as you because I have a pair of 2017 side guard...
Xray XB4
I have a 2017 XB4 I’m going to run 13.5 motor do someone no the best setup pinion gear to start off with thank you
