Like Tree248Likes
Xray XB4 thread
Old 04-27-2017, 10:44 AM
  #12346
snwchris's Avatar
IMO, its easier to run the gear diff, but that's just me. I think it offers more tuning options for tracks. I built my 16 XB4 with the Gear Diff back in December and have been super happy with it.
snwchris is offline
Old 04-27-2017, 11:59 AM
  #12347
Yeah pretty much similar to a 8th scale in a sense?
Expose193 is offline
Old 04-27-2017, 02:14 PM
  #12348
Originally Posted by lonslo
Hey guys I just ran mine on astro for the first time and had a issue with the left rear cvd popping out. When I look it's like the cvd doesn't sit in the outdrive as much as the other side at all. Both bones are marked correctly and match what's up with this thing lol
I have the same problem on my 2017. Earlier models had a problem where the RR suspension blocks were machined incorrectly, I believe this is still a problem. When I measured rear toe independently the left side needed correction. I offset the rear most pills, which corrected the toe problem but the left dogbone is still sitting further out in the outdrive as compared to the right side. It's better, but still not equal.
Tobey457 is offline
Old 04-28-2017, 05:50 AM
  #12349
symmetricon's Avatar
Trader Rating: 27 (100%+)
It should be quite easy to measure the rear toe block to see if its been machined improperly...
symmetricon is offline
Old 04-28-2017, 10:23 PM
  #12350
Trader Rating: 166 (100%+)
Default weird gearbox action (have a vid if anyone needs to see it.
At droop when I spin the spur gear, the right hand side spindle goes to full lock and the diff locks up the right side, only at resting ride height does it not do this. Have a video if anyone with any knowledge wants to see the issue. What could be wrong? I have redone the diff and case 3 times, and its the same over and over again.
jpcopeland1 is offline
Old 04-28-2017, 10:33 PM
  #12351
Sounds like driveshaft drops to diff outdrive slot.
Pushead is offline
Old 04-29-2017, 06:43 AM
  #12352
This happens when you have some sort of binding in the CVD joint. First make sure they are assembled correctly, I have seen people putting the cross pin through the concentrical hole in the barrel, this will give this result. If that is not the problem check for general binding, clean and re-grease.
Also check that the barrel is running freely and any wear in the shaft "eyelet" hasn't created a burr. A gentle sweep with a needle file should do the trick.
/Greger
GregerL is offline
Old 04-29-2017, 06:24 PM
  #12353
so I just finished putting my 2017 together and noticed that the left side outdrive does not stick out as far as the right side out drive. I could see the drive shaft popping out on the left side in a hard hit or landing. the difference in the outdrives is pretty obvious and limiting down travel seems like a band aid. the same issue is on the front diff. seems like two different outdrives need to be made for the diffs for each side since their is no shimming. I guess I could just shim the inside of the left cvd shaft to even things out but just does not seem right
AJrollin is offline
Old 04-30-2017, 02:51 PM
  #12354
Slapjack's Avatar
Trader Rating: 19 (100%+)
I drove my 16 xb4 for the first time on carpet yesterday and I'm just looking at making some setup changes. For the most part it was good but most setups I saw on petite (mostly Bruno setups) were 550 & 750 cst shock oil (I didn't have that heavy of oil so I was a little lighter) but I am ordering 42.5 and 55w AE oils now. Which is like 538 and 725 cst. The other thing was the roll bars. I had stock 1.2 and 1.3. Most of the setups were either 1.6/1.8 or 1.8/1.8. I am running mini darts and the car was rotating ok but maybe a little too much. Maybe too much steering so I may turn it down. But what would you all recommend for roll bars? Is 1.6/1.8 too heavy? Or does it work good? I was thinking maybe 1.4 front and 1.6 rear to try first. It is high traction but just wondering if thicker bars will make it easier to drive or harder. I am nkt very experienced at driving yet
If I
Slapjack is offline
Old 04-30-2017, 03:28 PM
  #12355
On carpet we would very rarely go lower than 1.6 in the front. Rear is either 1.6 or 1.8.
Of course it depends a lot on your track layout and overall grip level.....But this advice is pretty generic we have seen....
/Greger
GregerL is offline
Old 05-01-2017, 09:31 AM
  #12356
Trader Rating: 21 (100%+)
just installed the center diff and there is lots of play compared to the slipper which does not move at all neither back and forth are we supposed to shim the gear diff? also when i had it in i was hearing some chatter like it was hitting something it definitely moves while on throttle when i was just testing it on the stand
thanks for any help 17 xb4
toyota 2jz is offline
Old 05-01-2017, 11:57 AM
  #12357
snwchris's Avatar
Did you have the Center Spur on correctly, there are two side to the Spur gear one has a deeper cut out then the other, that might be part of the issue.
As for chatter I've have not noticed any with my 16 XB4 and have been running the Center Diff since December. There's nothing to shim for the center diff while in the mount. The bearing should line right up with the diff mount.
toyota 2jz likes this.
snwchris is offline
Old 05-01-2017, 12:07 PM
  #12358
thanks for the quick response ill look at it now and get back to you
Old 05-01-2017, 12:25 PM
  #12359
the chattering did go away the spur sits really close to the edge of the center brace is this normal id say 1mm clearance
Old 05-01-2017, 12:50 PM
  #12360
Trader Rating: 43 (100%+)
Whats the internal gear ratio of the 2017 xb4? Just wondering if its close to my TLR 22-4 2.0
Phillip F is offline
