Xray XB4 thread
Bent, how bout for med-high grip indoor clay (slicks and electrons tire of choice - almost cement like).
What screws would you recommend removing for the hard rear center chassis brace?
Right now I just have the 1 screw in front of the 2 bulkhead screws, but I was thinking of taking the one in front of that out as well...thoughts?
For dirt/clay we always start with medium chassis brace and add carbon stiffener starting with front screw and 2 rear screws for less flex if needed. Then add the 2 middle screws if needed.
Bent
When we remove screws from either the bottom of the chassis for the chassis brace or from the top for the carbon stiffener we always remove the middle screws, never only the front or rear. We always keep the front and the rear screw(s) in place.
Bent
Bent
also, how come the progression from the medium brace to the carbon stiffener, wouldn't the hard brace with some screws removed be a decent progression?
i prefer not to have to rebuild my entire car when i go on carpet, at this point i mostly do rebuild the entire thing lol - if it's worth getting the medium chassis brace I may but if you're using the carbon stiffener on clay i think the hard brace with screws removed should be okay.
how about the side guards bent for the clay in discussion.
yeah i always leave the ends screwed in, but for the rear rear, does the two bulkhead screws qualify as the end for you or you mean the first single screw?
1 in the front and 2 in the rear for the carbon stiffener.
We never run the hard chassis braces on dirt/clay only the medium braces front and rear and tune them with the carbon stiffeners and screws.
We also run medium chassis side guards for dirt/clay/wet astro.
Bent
End screws are the end screws
Bent
Bent
also im just swaying wouldnt the medium braces with carbon stiffeners be just as stiff as the hard braces with no carbon?
oh last question - on the clay were talking about do you run motor forward or backward? right now i run it forward with battery backward and 15g of weight behind the motor
again i really appreciate your time! your answers are invaluable.
ok thanks a lot bent. i couldnt remember if the brace went under the bulkhead or not off the top of my head.
We only run the motor in the rear on blown out low grip dirt.
For all the rest we run it in the stock position.
Bent
Car has more traction and is easier to drive with the medium chassis braces and chassis side guards. And if needed you can tune out flex by adding carbon stiffener with different number of screws.
Bent
Bent
Bent
Bent
do you run the battery forward or rearward on med-high bite cement like clay?
right now i run it backward with some weight on the motor side, but im wondering if with the medium plastics it would be a good idea to run it forward and have a little more balance.
i have been noticing more wear on my front tires, naturally from steering but it seems at the moment my rear tires are locked with traction while my front tires spin and pull me. this is actually super easy to drive and super fast this way but im wondering if i can keep the same rear traction and add a tad more front traction by using the medium plastics and running the battery forward.
i also have the front bulkhead braces to play with right now i have the stock brace for durability - thoughts on that versus the steering brace?
Just ordered medium plastics going to try that.
We only use the stock front top deck on super high grip carpet.
For everything else we use only the steering post brace.
Bent
i said battery position hehe just trying to see what works for you because i wont have time to do testing before my race.
but im going to try medium plastics with the battery up front and no weight behind motor.
thanks for your time Bent - that is all
Do any of you guys run a motor fan im running 10 minute a mains and my motor is way hot, ive tried everything except the motor fan?
Outdoors on dirt, clay, wet astro etc with boosted 6.5 turn we usually run without a fan.
We never run more than 6 minutes though
Bent
yes, 5.5t on a carpet track and the motor was running quite hot. WTF Trumpet fan makes an awfully loud racket but keeps motor completely cool
try it with 300k-1M and you will feel the difference in jumping, acceleration and more even tire wear.
