Xray XB4 thread
#7201
Maybe they will have to stipulate the purchase of the Hudy setup board before doing the replacement.... just kidding...
#7202
In case you guys missed all the discussion leading up to this, the Hudy setup board WILL NOT show the issue. They should never have put that in there, unless they're hoping some will miss the problem. The Hudy setup station is useless in this case, as it only measures toe in relation to the other wheel, as was stated, you could mount your whole rear end sideways and it would still say 3 deg.
#7203
The 4-hole steering plate we are using on the 4WD is now released.
This sharpens the steering response and let you have a more aggressive steering setup.
Works really good with the Alu. 12* C-hubs on high grip tracks
Bent
Bent
XRAY presents Alu Steering Plate 4-Hole #362573
Aluminum steering plate CNC-machined from premium Swiss 7075 T6 aluminum. Designed & recommended for use in high-traction conditions. Increases steering precision and predictability. The steering plate features extra Ackermann positions for very precise steering adjustment.
• For high-traction conditions
• Increases steering precision
• More predictable steering
• Extra Ackermann positions
• 4 holes
• More forward Ackermann positions
• 4 holes
#7204
Running the lighter shorty setup also makes it easier to tune the shocks for bumpy tracks/sections
Bent
#7205
Bent
any new clay setup sheets with the newly released parts? I'm running the clay setup from the xray site.
#7206
Martin B. is over in the US at the moment for the DNC and some testing.
Hopefully he will be able to squeeze in some 1/10 time as well.
Malin might start to run her #2 car on indoor hard packed clay here to test some as well.
A track we normally run Super Soft BarCodes type tires on.
Bent
#7207
Has Xray started putting the "corrected" rear hinge braces into their kits yet? Just picked up a new '15 from the LHS and they said it was a newer kit (one they just got in).
Just curious if I need to match or mis-match my rear inserts for equal toe in.
#7208
If you are in the USA then I highly doubt you got the updated part. I haven't heard of anybody getting it yet, and your kit was probably packaged at least 2 weeks ago before it found it's way to an LHS. Just measure each insert hole from the screw hole, or post a pic as most of us can see it by eye. Or assemble it and you will probably notice it.
#7209
#7210
Sorry, not yet.
Bent
Bent
Will the new steering plate be usable on loose conditions as well? Also wanted to ask if the 3mm chassis will work on loose conditions with out using any upper deck braces?
As always thank you for sharing your thoughts.
#7212
Speaking of this, I did manage to get my kit built last week but I'm not sure if mine is out of whack in the rear end or not. It looks to be okay but I may be looking at the wrong thing haha I'll post pics of mine tomorrow morning.
#7213
#7214
It's already gotten a part # and is ready to ship any time now.
Wether the 3mm chassis would be the preferred choice in loose conditions I honestly don't know yet.
But from testing so far Malin really likes how it handles without the top decks and more roll incorporated into the setup.
I can see this setup being a good starting point for a loose / low grip setup
We will do some back to back testing with the new and "old" chassis in loose conditions as soon as the snow has disappeared and the outdoor tracks are good to go again
Bent
#7215
Hey, im interested in Malin's 4WD setup for this track:
https://www.youtube.com/watch?v=9ZqqiMmPCvo
Didnt find any on teamxray.com (except XB42WD)
How center differential works on carpet compared to clutch.
What center diff oil you suggest for capter?
This is very close to our starting setup for anything carpet.
We usually only adjust front and rear oils, front sway bar, ackermann and roll centers for the hinge pins.
Malin like's the feel of the center diff the most (with 1.000.000cst) but she's faster with the center diff so that is what we ran this time.
Malin's XB4 4WD '15 EOS setup
In the video she's starting as #4 in the C-final, after some bad luck with other drivers in the qualifiers, and ends up as #3.
She's catching a lot of traffic on the last 2 laps and having some problems getting past slower drivers crashing (and stopping on the back straight) and is almost caught by the driver behind her when trying to safely bring home the 3rd place finish.
The last lap in the video isn't counted as they had already passed the finish line within the time limit.
Also super happy with her speed in the last final where she did a 16 lap in 5:02:349 and medium time of 19.995.
Miguel Matias' best B-final time was 16 laps in 5:04:632 and a medium time of 20.126.
Martin Bayer's best A-final time was 16 laps in 5:01:482 and a medium time of 19.914.
Martin Sinn Wollanka's best A-final time was 16 laps in 5:00:335 and a medium time of 19.813.
Being faster than Miguel Matias and just 0.867 a second behind Martin Bayer's fastest A-final time is really her best achievement so far
And she was just 2 seconds behind Martin Wollanka's best A-final as well.
+ YouTube Video | |
Her setup in the video:
Xray XB4 4WD '15
ORCA VX3 esc
ORCA RX3 5.5T motor
ORCA Infinite Ultra 2S | 90C | 4800mAh shorty battery
Futaba S9353HV servo
Futaba R304SB-E receiver
Futaba 4PX transmitter
Bent
