Xray XB4 thread
#4832
Does anyone try this rear shock installation for bumpy track ?
#4833
have saw that there is a DCJ kit from Spec-R for XB4.
have anyone tried it out? i need some feedback before i plunge into getting it.
http://www.spec-r.com/default/index....roducts_id=557
from what i understand from touring car drivers, DCJ smoothens out the steering in TC. I've tried it on my TC, and it does helps alot. however, i'm not so sure if it is a necessity for off road.
#4835
gearing
I need a good starting point on gearing.
I'm running in a "stock" 13.5 class. No timing or boost in the ESC.
I'm being told to shoot for a final drive ratio of around 7. But I can't fit anything bigger than a 26t pinion. And to get near the 7, I need a 28 or 29 with the 81t spur.
I've tried 26 and 25 pinions and to make any speed I need to add ~20 degrees of motor timing. Plus, I can't make a long double jump that others can.
Help, thoughts?
Help, thoughts?
#4836
Awesome option to play with if you need some rear traction
Replaces the plastic shim under the rear diff.
http://www.warny.pt/store/xray-xb4-rear-weight
#4839
And your XB4's CVD will say thank you
Olivier
Olivier
#4840
After several searches and rewording the search..lol...
Looks like I'll be ordering up some AE spurs and going that route.
#4842
Hit a car parked on tge straight full speed, brokefrnt shock shaft, bent front universal abd broken frnt bulkhead
Used a kyosho shock shaft, ae bottom shock shaft eyelet piece, straightened out the uni , ca glued tge bulkhead to finish off tge day lol
Expensive day at the track
Not to mention tgey put 40 pounds of sugar on a hard packed dusty surface which ate through 2 sets of brand new tires
OuCH
OuCH
#4843
LOL Been there myself. Sucks for the wallet, but I LOVE the ingenuity!!!
Pics PLEASE!
All these sugared tracks… is it really necessary? Is it really "Off-Road" racing if you're driving around stuck as if F1 slicks on asphalt? I think the Red clay is sticky enough but dirt enough to be the standard surface which every sanctioned event should use. If you want that kind of grip, run on-road.
Pics PLEASE!
#4844
