Xray XB4 thread
#3258
Nope not arguing.
But I had to go down and look at the chassis we have been using since it came out and the wear is minimal and all 3 XB4's are as straight as new.
So I would rather prefer the chassis to be adjustable as it is with flex screws, top deck and braces instead of having a stiffer chassis which would limit tuning options
Because IT WORKS as is
Bent
Bent
#3259
Finally got around to pick up Malin's new rides for the 2013/2014 indoor season
Running Orca Vritra VXX ESC's, TX motors and Infinite batteries.
Can't wait to let her try out the new '14 edition of the XB4 (one for indoor clay and one for carpet) and the new electronics setup
Bent
Bent
#3260
Bent
Bent
#3261
#3262
In Sweden they are selling at some shops.
#3263
I've picked up the two +2 rear lower suspension holders today from MB Models.
363311 and 363321. They are shown below compared to the regular kit rear ones.
I've modified (Dremel) the kit RR holder to allow it to be mounted directly to the chassis, as i'd already removed the plastic rear section of the chassis for the ralls racing under-gearbox weight. I ran the car with the dropped gearbox and modified kit hangers on my slippy and it was excellent. Really helped lock in the rear of the car.
I've now got the new optional +2 hangers and they raise the mount points higher/closer to the outdrive by 2mm. really hoping this helps to lock in the rear end more on the slippy stuff with the dripped gearbox. Testing Sunday, will feedback.
Anyone else done this yet?
#3264
I see a lot of xb4's for sale stating v2 upgrade. Does that mean that the seller has upgraded to the 2014 edition that is coming out? If so, why sell. Looking forward to the '14 edition, X-ray site shows lots of changes on the car.
#3265
Nope. Absolutely not. If it was a '14 it would say "14." V2 was sort of like a 2013-1/2.
#3266
Please help guys my xb4 is runnin hot. After two heats we tightened up my slipper and was running about 160 at 5 minutes and after the main 8 minutesI was at 185-190 on the can and 160 on the esc. I'm running the pro trak esc with protrak 6.5 motor with it set one about 20 degrees timing and blinky on the esc. My current gears I'm using is 16 pinion and 81 main and I'm still getting hott. Here is a picture of my track and I have a 84 main gear I can use but don't know what to do. I haven't rechecked my slipper to see if its fried already but I don't think its that the track is about 100x50 with a long straight
#3267
The track above has a lot of traction but I don't want to hurt my electronics maybe a 6.5 is to much for the track or should I get a fan for the motor maybe. I ran fastest lap of the night out of all classes and took first but I'd rather not hurt my electronics
#3269
Ran with the dropped gearbox, centre insert, lower inner show tower, outside hub hole. I went to 4 deg caster and 1 deg anti squat, as well as moving to lower outer ralls racing tower hole, which helped a little. Far looser than it was previously however? This is meant to be the xb4 low traction mod?
What effect on roll centre does this mod have? If moving the top ball down raises the roll centre, does moving the bottom pin up lower it?
With moving the gearbox down, and the wishbone pivot location up, do you need to move the top link up a bit also? Any help or feedback would be useful...
#3270
Thanks I will put it on 15 on the can as that's the lowest I can go but if I'm at 16/81 i don't understand gearing then because you guys are running 19 pinions and I'm at 16/81 should I put on a bigger main gear like the 84?
