Like Tree248Likes
Xray XB4 thread
Old 10-12-2013, 08:07 AM
  #3136
advpball's Avatar
Trader Rating: 30 (100%+)
So do you suggest taking the chassis screws out on bottom..I m thinking 4 down the center.
advpball is offline
Old 10-12-2013, 09:09 AM
  #3137
Trader Rating: 36 (100%+)
Originally Posted by Jay rb5
Any help would be appreciated. especially from an actual xray owner..
im running on a mid size (90x45) indoor hard packed clay that is smooth and wet with lots of grip. we shave down M4 suburbs to slicks all around. my issue seems to be rear traction as im on power the rear seem to slide more than I'd like. the set up is pretty much box with the exception of 9degree front hubs.
thanks
Jay
I might be mistaken but if not, this should help give others a better idea on how to help.
http://youtu.be/dlXTNGlpPsE
YW -Oompa
NitroOB4You is offline
Old 10-12-2013, 10:34 AM
  #3138
BentKa's Avatar
Originally Posted by advpball
indoor dirt med traction..small track 42x60? running 7k front 3k rear I think someone had that posted so trying that.
Originally Posted by joeymdz
Depending on your traction level you could even go to 5f/3r on the diffs. I found it a lot easier to drive when the surface was a loose/medium scenario.
We've had great success running F:5 / R:3 on loose to medium tracks
On high grip tracks we've actually found it to perform better with front & rear diff weights very close (6/5)
Bent
BentKa is offline
Old 10-12-2013, 10:46 AM
  #3139
BentKa's Avatar
thanks
Jay
Is this coming out of corners ?
We've been really pleased with running long camber links in the rear (outer hole on hub) and adding 0.5 of anti-squat.
You can also add some rear toe (going out on the RR holder).
On tight tracks we have then used the inner lower roll center on the hubs to get some rotation back
Bent
BentKa is offline
Old 10-12-2013, 12:10 PM
  #3140
Pulse_'s Avatar
Back from our first try with the XB4
here is the track (the pic is from last year)
here is the car
and I have to say... I LOVE this buggy. Very natural feeling, good balance, great steering, neutral on jumps, easy to drive. Overall I've nothing negative to say about its handling, ii is VERY good. I didn't have the good tires with me because the track was wet but I can't imagine it being even better on the dry, I'm really impressed.
Pulse_ is offline
Old 10-12-2013, 12:57 PM
  #3141
Trader Rating: 36 (97%+)
Bent- yes, I feel it mostly coming out of corners. I will test the longer camber links and anti squat. thanks
Jay rb5 is offline
Old 10-12-2013, 04:27 PM
  #3142
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by BentKa
You do as you wish.....it's your buggy
Bent
anything but shim the diffs.....
asc6000 is offline
Old 10-12-2013, 06:03 PM
  #3143
all i can say is that i never own or drove a 10/th scale till now i raced this weekend and my god this xb4 is awesome
billsharp34 is offline
Old 10-13-2013, 09:58 AM
  #3144
advpball's Avatar
just say love the car handled good few tweaks from stock.The question is front and rear hangers are wearing after 5 or 6 packs.ride hight 18 or 19mm, rsn 5k front and 3k in rear.
drove poorly but let the a maind winner run it after and said he liked it a lot.Really good for first run.
advpball is offline
Old 10-13-2013, 07:59 PM
  #3145
Trader Rating: 9 (91%+)
What are front and rear hangers?
leongkc is offline
Old 10-13-2013, 08:10 PM
  #3146
JasonR/C's Avatar
Any word on release? I hear xray is quick with release once a product is announced. When should I plan to see this? Is there a typical xray timeline?
JasonR/C is offline
Old 10-13-2013, 08:11 PM
  #3147
joeymdz's Avatar
Ride height on dirt should be more around the 20mm. What are you running for shock oil. The suspension holders aka "hangers" will get scuffed.
That's nice that the a main winner liked your car but what did you need more from it?
joeymdz is offline
Old 10-13-2013, 09:43 PM
  #3148
big chris's Avatar
Trader Rating: 51 (100%+)
Anyone know a US store that has 365114 (bevel gear) in stock? First weekend on the XB4 and slipper was too loose at first then apparently too tight. Was super awesome even after it lost a few teeth!
Also does someone have a pic of both (V1 and V2) 35T Bevel gears side by side?
big chris is offline
Old 10-14-2013, 01:09 AM
  #3149
Hi, may be this can sound silly, but while i was doing the shock i noticed that the progressive spring got more coils on one side than the other side.More coil=softer and less coils=harder. Is that right?. If that is right more coils on top and less on the bottom of the shock.
Could anyone please tell me if i am wrong or right?
Thank you
marco cianfrone is offline
Old 10-14-2013, 01:27 AM
  #3150
BentKa's Avatar
Thank you
It doesn't matter which way you orientate the spring.
The spring will compress just the same either way
I usually have them mounted with the markings on the spring facing up to be able to identify them quicker
Bent
BentKa is offline
