Like Tree248Likes
Xray XB4 thread
Old 02-14-2013, 11:49 PM
  #1606
RShockley's Avatar
Originally Posted by Deaner
Ohhh ok so basically you just lapped the top of the shock body where the cap seats against it? I'll prolly end up building the shocks just like the manual says and see what happens, if I get leakage from that area I'll give your trick a go, along with the black grease on the threads. Do you think maybe the rear diff issue has something to do with possible differences between the two diff cases? Tolerance wise? The front and rear diff cases are interchangable, no? Funny that the rear diff would wear different from the front; all things being equal. Think I'll marinate the diffs in diff oil (and worcester sauce) before assembly.
Thanks for the insight, I'm still fairly new to this hobby and I'll take all the help I can get!
The front and rear cases are not interchangeable. The front case has a stepper angle where the top plate attaches to allow for kick up in the front.
Cutting the top plate is due to the added thickness of the front diff case where the tower attaches.
RShockley is offline
Old 02-14-2013, 11:59 PM
  #1607
Peakki's Avatar
Originally Posted by asc6000
Also why the extra big gears? Haven't heard that being a big issue. Nice though.
Taken from www.teamxray.comj
Improved 35T diff gears V2 - they have symbol 35 on the back of the gear. Replace both front and rear. The new gear reduces play of the internal satellite gears inside the diff to reduce the risk of damage to the satellite gears.
The reason is simply that. With the new big gears the small gears move closer together and have less play = less breakages.
Peakki is offline
Old 02-15-2013, 02:34 AM
  #1608
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Originally Posted by BentKa
Been running metal gears and the hard coated lightweight pins for over a month 3-4 times a week with no issues.
Now running the new 35T gears as well.
Works just fine and adds a little reassurance
Bent
Do you have a part # for the lightweight pins?
Jamison R is offline
Old 02-15-2013, 02:38 AM
  #1609
slakr's Avatar
Trader Rating: 36 (100%+)
335081
slakr is offline
Old 02-15-2013, 03:37 AM
  #1610
BentKa's Avatar
Originally Posted by slakr
335081
Bent
BentKa is offline
Old 02-15-2013, 03:47 AM
  #1611
Jamison R's Avatar
Looking everywhere and cannot find these pins. Amain, stormer and nexus are all out of stock. I cant even find them on fleabay. Are there any reputable euro shops that ship to US that might have this part?
Edit: just found them at apex models in UK. I hope they are reputable. If not its only a $22 PP claim. Fingers crossed.
Old 02-15-2013, 05:23 AM
  #1612
j0pp3's Avatar
Apex Models are well known in Europe so you don't have to worry.
j0pp3 is offline
Old 02-15-2013, 08:52 AM
  #1613
seth556's Avatar
Trader Rating: 43 (100%+)
I just got some of the pins off backorder at RC America, so they'll probably be back in stock everywhere soon.
seth556 is offline
Old 02-15-2013, 10:08 AM
  #1614
aloksatoor's Avatar
You don't really need the metal pins. I use mine with front rear metals with the stock plastic plus like part. That part is not under stress too much.
aloksatoor is offline
Old 02-16-2013, 01:32 PM
  #1615
In 1,5 day (with a working day in bewteen) I built the XB4. Nice car to build. The build had to go quick because tomorrow is a race day (Usually I only race 1/8 nitro)
I've drove the car today and recieved some custom made parts for the XB4.
a new topdeck, front brace and 2 shocktowers out of some compositie material.
Topdeck installed. This will stop bending the chassis forward and has a big influence on the flex of the chassis.
Installation of the front brace:
Shocktowers:
I tested the Xray stock and adapted the setup and installed the custom parts just now. The result has to be tested in the race .
But pinion 19T on a hacker 5.5 is already fast. But I think for outside racing it needs to be geared a bit higher (or enable boost).
Huske is offline
Old 02-17-2013, 08:19 AM
  #1616
kenny lutz's Avatar
Trader Rating: 38 (100%+)
I ran it for the first time last night and was very pleased with the car it is tight off power I was running 7k front 5k rear and switched to 5k and 3k but it was still pushing off power any suggestions?
kenny lutz is offline
Old 02-17-2013, 01:49 PM
  #1617
Does anyone here run 17.5 blinky on their XB4?
I am wondering what pinion I should try for stock on a outside clay track, medium sized...
Hars is offline
Old 02-18-2013, 07:54 AM
  #1618
kenny lutz's Avatar
i would prolly say it wont work just because the wieght of the car and being 4wd. i think you need aleast a 9.5 imo.
Old 02-18-2013, 01:14 PM
  #1619
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
13.5 would work depending on track size. The drive train in this car is very free.
Qwkrn U is offline
Old 02-18-2013, 02:11 PM
  #1620
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
So with a 10.5 what kind of boost would I need to be a mild setup? And what pinion?
jlfx car audio is offline
