The AE FActory Team B44.2 Thread
#2116
#2117
#2120
FYI on the ballcups... The ones in the kit are not the same as the ones you can buy seperately!!! It's only $5, put a set on and see how many you have problems with then.
The diff tool is neat. I never pop my cups off either to adjust any diff.. I just remove the 2-56 capture screw on the arm and pop out that side intact.
#2121
Your going to have to give a set up then. I'm assuming M4 is soft? I don't know those tires at all. Start with oils and pistons and if your running drag brake.? I can say this my kit will turn on command. No drag brake absolutely no lack of steering at all. You could try different tires. His set up weight or just out right kit could be an attribute to the tire. Inserts are a good thing to consider. Are you running the same?
#2122
#2123
My 44.1 and 44.2 have a ton of steering especially low speed and tight. I never run the ballast either. Only a 1/2 oz between the cells and a really soft rear spring.
Would have to see your whole setup.
#2124
#2125
Your right.. hes going to have to give us the whole set up. It could be a lot of things..
#2127
I never pop a cup for an adjustment or when breaking in my diffs in any car. Just pull the hinge pin out.
#2128
Un4
Had a kinda of a good show with the b44 in our N/w ShowDown Tour yesterday
Qualified 3rd .
in ft of all our B44.2's
1st & 2nd got 23 lap 6:12. I got 23 6:13...
There were 2 mains
1st one was in 2nd with lots of crush & slapped a little on landing.
ESC switch turned off somehow .
2nd Main cracked a ft arm on warm up & it fell off 6 laps into the heat..
Love this machine , had a blast with that qualifing run ..
Was a dream come true the whole 6 min ....
Qualified 3rd .
..1st & 2nd got 23 lap 6:12. I got 23 6:13...
There were 2 mains
#2129
Un4
Qualified 3rd .
There were 2 mains
Qualified 3rd .
There were 2 mains
#2130
Un4
Qualified 3rd .
There were 2 mains
Qualified 3rd .
There were 2 mains
Sounds like they need faster motors.. Check this 44 out, I sold him a set of .2 battery holders and he put them on his 44.
That comes from running one class and getting real bored between rounds...
Let me know if you need any measurements.
