The AE FActory Team B44.2 Thread >
Old 12-25-2012, 09:32 PM
  #1366
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Should I use alcohol to clean it? Or soap?
ryanpatrickgore is offline
Old 12-25-2012, 09:37 PM
  #1367
bigs's Avatar
Trader Rating: 46 (100%+)
Finger nail polish remover should work well.
bigs is offline
  #1368
ksarantakos's Avatar
Acetone will clean up CA but I'd try going over it with a black sharpie first and see if that makes it presentable before rubbing a solvent all around the chassis edges.
ksarantakos is offline
Old 12-25-2012, 09:50 PM
  #1369
fq06's Avatar
I found it best to apply with a q-tip but getting the cloudiness... not sure. Maybe a debonder wiped on the edges?
http://www.caglue.com/US-1-bSuper-So...glue_p_35.html
Their super super t medium CA works really well on tires and your get about twice as much as the normal tire glue bottles for the same price... as a side note that may benefit you.
http://www.caglue.com/Super-T_c_16.html
fq06 is offline
Old 12-25-2012, 10:45 PM
  #1370
It's not even in the edges..
It's on the top and bottom. Weird huh
Old 12-25-2012, 10:50 PM
  #1371
lodhammerdin's Avatar
Trader Rating: 77 (100%+)
Superglued around edges of chassis and towers.
But it left a white residue... How do I get it off and make it look nice again ?
I sand the edges lightly first, then, a thin layer of glue. let it dry overnight, use 800 grit on that. Then, I use some model paint to paint the ca on the edges and let that dry and then ca over that.never had it come out funny.
lodhammerdin is offline
Old 12-26-2012, 12:12 AM
  #1372
Trader Rating: 34 (100%+)
Originally Posted by Sarinexia View Post
Hi Guys,
Been interested in going 4x4 1/10 buggy and of course been eye-balling the B44.1 for a long time, then this bombshell was put on me a couple of days ago.
I've read up to date on this thread. Good conversation contrasting between .1 and .2. However, I am curious what exactly many of you would do right off the bat for any hop up's? What are your weak point concerns?
Also --- Servo recommendations. No need for a $99.00 servo.
I think i'm going with a Tekin RS / 8.5 Redline.
Look forward to the responses.
below are the stuffs i placed in:
http://www.ebay.com/itm/TSR-Team-Ass...item2a236489a2
Works like wonder, eliminated some noise as well as dust collection
http://www.ebay.com/itm/TSR-Team-Ass...item2a2364907d
Not bad, but don't bother to place in your front, it will cut through after all the steering turning. eliminated some noise as well as dust collection
http://www.ebay.com/itm/300455086232...84.m1439.l2649
Have been using this on my b44.1 and b4.1.
http://www.ebay.com/itm/200855721934...84.m1439.l2649
only fitted one part from this product, cos The other part don't fit in.
bought
Jconcept silent spur gear
lastly, Hobbywing V3 and 8.5T motor.
Ran this setup last SUnday. noticed that the car become very QUIET!!! still fast though. The silent makes me feel as though i'm losing power, but it's still as fast
sion is offline
Old 12-26-2012, 04:38 AM
  #1373
thebomber's Avatar
Did you use a black sharpie on the edges first?
thebomber is offline
Old 12-26-2012, 06:46 AM
  #1374
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
The white residue will not affect the handling. Put it together and go drive it.
CHIZZLE is offline
Old 12-26-2012, 07:49 AM
  #1375
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Wrong, it greatly affects the cars consistency on turn in, helps on corner exit but lap times will suffer over all.
Like I posted in his other thread, Acetone on a rag. A quick wipe on the actual edges can "shine" them up a little too. It evaporates so fast there's no worry of actually affecting the glued edge.
racer1812 is offline
Old 12-26-2012, 08:31 AM
  #1376
Suspended
Trader Rating: 89 (100%+)
Hey, if any of you guys want a Tony's screw kit brand new, I've gone one. Just sold my B44.2 ---- This is one of the extras.
Got some spare parts too N.I.P. PM me if you guys want.
Sarinexia is offline
Old 12-26-2012, 10:10 AM
  #1377
rigor's Avatar
Trader Rating: 44 (100%+)
Originally Posted by wpack03 View Post
Just follow the manual and make sure you pay attention to EVERY step. Most of the build problems in this thread are the result of people overlooking steps or putting parts on wrong (upside down, left v. Right).
Exactly this. Look at every word and picture in the manual carefully and you'll be fine. The build is very good. Many folks don't like the AE ballcups, so you might want to just build with other ballcups such as RPM. Take your time on the diffs and shocks.
rigor is offline
Old 12-26-2012, 10:16 AM
  #1378
Haha! Lol
Thanks all you guys for the help
Old 12-26-2012, 12:10 PM
  #1379
Quick question about this build. I am on the shocks and the o rings that seals the shock cap and the o ring for the shock collar look identical but different part numbers. Which ones are which. Thanks in advance.
Millerracing is offline
Old 12-26-2012, 12:41 PM
  #1380
Matt Howard's Avatar
coming from a Durango these ballcups are freakin awsome. You even look at the Durango cups wrong and they pop off, forget about trying to adjust a turnbuckle,.... pop
Matt Howard is offline
