Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 10-30-2012, 11:19 AM
  #2236
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
gotcha
Posvar is offline
Old 10-30-2012, 12:15 PM
  #2237
t8rtot's Avatar
Trader Rating: 14 (94%+)
i think going to the +4 caster in the hub will be my next move to calm down the steering.. the rear is locked in. how is the balance dropping the rear spring one rate?
i see ppl are going that route.
t8rtot is offline
Old 10-30-2012, 12:29 PM
  #2238
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Are you running MM, or RM? I thought I saw you mention you were going to MM.
I am running RM, and find the pink/red front and rear combo to NOT be ideal with the weight balance of the new car. There is a lot more weight on the front of the car in comparrison to the rear than there was with the RB5, and the car has a bizzare amount of steering. I am running golds front and back and it feels a LOT better. (37/30)... but still have a lot of testing to do.
Cpt.America is offline
Old 10-30-2012, 01:09 PM
  #2239
rcfiend's Avatar
Trader Rating: 42 (100%+)
Check out the goodies from Diggity Designs http://www.redrc.net/2012/10/diggity...Car+News+DF%29
rcfiend is offline
Old 10-30-2012, 01:21 PM
  #2240
t8rtot's Avatar
both, i bought another car i'll do "midship" with
i wanted to at least get a base with rear motor. so you went up two springs in the front, dropped on in the rear. using 0/2/4 caster? and where is your battery?
t8rtot is offline
Old 10-30-2012, 01:33 PM
  #2241
Trader Rating: 166 (100%+)
Originally Posted by frito
Ready to do work
Tasty nasty.....
jpcopeland1 is offline
Old 10-30-2012, 01:40 PM
  #2242
RudeBits battery strap copy!
mikeyscott is offline
Old 10-30-2012, 01:48 PM
  #2243
Im running the 4 degree caster inserts, and im running a full sized normal lipo right in the middle of the car in front of the ESC. I have since moved to the RB5 carbon fiber battery strap, but here is a shot with my battery and wiring:
Old 10-30-2012, 01:50 PM
  #2244
aloksatoor's Avatar
Trader Rating: 43 (100%+)
who copied from kyosho. Nothing new same design there. hoping exotek comes up with something like they got for the 22.
aloksatoor is offline
Old 10-30-2012, 01:55 PM
  #2245
Moderator
Posvar's Avatar
Posvar is offline
Old 10-30-2012, 03:35 PM
  #2246
I like using the RB5 battery strap in my car. Keeps my lipo in place much better then the plastic Kyosho part. How do you get those inserts out of the caster blocks. I want to try 4 degrees but those suckers are in there good.
Old 10-30-2012, 03:41 PM
  #2247
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by rokitman
I was just looking at the pics that people have posted. Is there a reason noone is using the channel for the wiring? I ran my servo wire through it.
Didnt know if there was a problem with doing this, I just thought it was alot neater in it.
I'm using the channels, although, for the esc wire not the servo wire as my rx is mounted directly behind the servo
silvalis is offline
Old 10-30-2012, 03:42 PM
  #2248
aloksatoor's Avatar
Buy new knuckles . How did you use the rb5 strap though guys? I just checked the holes are wider on the rb5 than the 6.
Old 10-30-2012, 03:43 PM
  #2249
They are a b1tch! I punched it out with a big hex driver... one of them flew across the room! I used black grease on the outside of the 4s before I installed them, so hopefully they pop out easier if I ever have to take them out. Careful not to stab your hand!
Old 10-30-2012, 03:44 PM
  #2250
there is another set of holes in the rb6 chassis. same width as the rb5. More towards the middle of the car. I dremmeled my RB5 battery strap nice and short. You have to use a 2mm shim underneath the rb5 ALU battery posts, and it works like a charm.
