Kyosho Ultima RB6 & RB6.6 Car Thread
#2251
But screw the saddles I think I will go with a shorty first then a full pack. All I got is hobbyking saddles and some gens ace lil puffed.
Full packs a ip 6800 and a 70c protek shorty so preferred for racing anyways.
#2252
Actually got to "race" the RB6 for the first time this past Saturday (prior to that just a day of practice).
The car is amazing.
Large outdoor track (SRS: Cactus Classic track)
Before the weekend, I had decided to switch from 'standard' packs to 'shorty' packs. Honestly I did it so I could have cleaner wiring (I did not like my receiver sitting on the side). After driving the car with the 'shortys' it was great.
I still had a bit too much steering, so this weekend I am testing the 4d caster instead of 0d.
My setup was a mix of the 'Japan All Around' and 'Kohta Akimoto'
differences: 0d caster, .5 rear hubs. (setup attached)
Wiring Before:
Wiring After:
The ESC and Antenna wires are ran through the channel.
Now I have the carbon straps coming in also.
Dean
The car is amazing.
Wiring Before:
Wiring After:
Dean
#2253
You put a 12.5 rotor in place of the 17.5 rotor?
Turn the degrees on the can to max?
Told ya I was new to electrics...lol
Mine is a stock tekin, guess I have some stuff to buy..lol
#2254
That 12.5 refers to the diameter of the rotor, in this case 12.5mm. It has nothing to do with the turns (rating) which, also in this case, would be 17.5 turns.
#2256
Moderator
Trader Rating: 470 (100%+)
That is why I bought extra knuckles.
#2257
midship
I will be testing and tuning with MM motor this weekend at the club race . with the run up to the big double i am putting in a 17.5 from the 13.5 should be able to carry more corner speed without a lot of wheel spin on the tight track . i have a good starting point should be fun at any rate .
#2258
#2259
#2260
It seems a tire with less tread (worn down) would grip better
#2261
Myself and a few friends are planning on running mid motor for one race and I need a decent if not good MM setup. I have run midship before with a DEX210, and Schumacher Cougar SV2. What are you running as far as ball stud washers. Any additional weight out back? This is going to be done on very wet clay.
In the rear the camber links are as low as possible and as short as possible
Shock setup:
Pink springs in the front with stock pistons and 32.5wt associated shock oil
Gold springs in the rear with stock pistons and 25wt associated shock oil
I also run the wc rear a arms. And .5 degree hubs.
No weight, any where
#2262
In the front i am running the camber links as long as possible and 1mm under the ball stud on the bulkhead.
Shock setup:
Shock setup:
#2264
yeah won't know if i don't try it . car seems very balanced and has a lot of rear grip as front . i ran it on an outdoor track that has loose dust just to try it the car hooked up nicely . equipped with revtec 17.5, speed passion revention pro, turnigy nano tech 4200 65c shorty , spektrum s6040 servo, and sr3100 receiver, no weight added car with no shock fluid balanced perfect with the stock springs .
#2265
Trader Rating: 89 (100%+)
suspension???
Can someone explain how the wider suspension nholder change the cars performance versus the narrow holders and are you guys using the new arm or have you gone back to the older WC arm?
