TeamC TS4-TS4Pro SC thread
#76
I think the picture is deceptive. The droop is equal to the rear. A friend at our track is setting his up using the stock shocks, so we will get some back to back testing in soon. It would be ideal to use the stock shocks, but I really think they are just too short. There is already 50wt oil in the front, and i will try both 7k and 10k in the front diff in the next few weeks. Our outside track is like running on concrete and seems to amplify steering, but our inside track has medium traction at best. so far this combo seems to be very drive able in both extremes.
#78
#80
Issue with Diffs
Well, I have one issue that has cropped up a twice now. I'm guessing its my driving or something. I have managed to chew up both the front and rear diff gear. I had taken the car apart to refresh the fluids and noticed a few teeth actually chipped off. Anyone else having issues with the diffs teeth getting chipped?
#81
#82
Yeah, after the first one. Ckhobby suggested going to red locktite. i had used blue locktite a little thinner i think, I looked at the pinion gear. Definitely not loose or no screw backing out. One of the chips was a big chunk of a tooth. The rear had a couple spots where the teeth where chipped. Was really looking forward to running tonight and saturday to see how these changes would do. those are the breaks though. Make sure you check yours though.
#83
#84
I actually did this on my truck the first time out and it was because i didnt have all of the dif case screws down tight. the holes are a touch on the small side and even though they felt tight they were not down all the way and that misaligned the gear mesh. Once i made sure and got them down all the way it has been perfect.
#88
BTW tried a 6.5 540 motor yesterday...........entirely too much motor! GEEESH it was yankin the wheels everytime the front would bounce up! and it got hot quick, i had a 13t on it and im not really sure that running a 10t will be enough of a drop to keep it cool. I do like the feel of it though, its really smooth.
#89
#90
Really interested in this truck, love the design as soon as I saw the first real product photo. Pretty much a durango with ability for a regular battery.
*I've heard racer need two shorty instead of saddle to make the battery last a 10 mins race.
The question right now is how's the durability of it?
The part support is nowhere near as good as the AE and losi stuff.
What spare part do I need to get it with?
I've seen the gear box is holding most of the suspension, using 3 screws on one side, so maybe some dirt cheap gear boxes in case it's stripped?
is the suspension arm strong enough after some terrible jumps? (i.e. fly high and land on one wheel)
and whether the cvd is reliable? I've bent 5 sc10 4x4 cva bones already, it's much better after putting the spacers in the shocks.
BTW, the esc can only be double sided taped on the chassis. But from my experience in sc10 4x4, no tape is strong enough to hold the esc in place after a few crashes. I've even tried 3M dual lock and it failed.
The best solution is to zip tie the esc to the chassis, but TS4 doesn't seems to have the space for it.
