TeamC TS4-TS4Pro SC thread
Just completed the build last night and the maiden voyage will be this evening.
more details will be added later, but here are some pix!
Excuse the wiring, I am also sponsored by Brushlesshobbies and am testing ESC's at the moment
Info:
Some spring information:
"The more lazer etching marks, the softer the spring.
The stock Big Bore springs are considered Mediums, but they are not marked. When you buy stock replacements, such as the TU0250F/R, you will then see double etch marks on both ends, indicating "Medium" rate. The options available are the single etch marked Hards, and the triple-etch marked Softs.
The current set of Big Bore springs were all originally designed for the front and rear of the TC02 buggy and TC02T stadium truck. Therefore, when setting up an SCT, it has been best to use long (rears) in the front, with or without the little helper springs, depending on chassis weight/bias."
Some info here:
To get more droop, traxxas slash 4x4 front TiNi shafts add 2mm more droop part# 1664T
Also, traxxas 39mm aluminum links work for the steering and front camber links, and the 59mm links work well for the rear.
Some info here:
rear driveshaft is at an angle to clear the battery, just like the Durango DESC, which my last truck and that is never an issue.They are CV joints just like the what drives the wheels only stationary.
I own RCShox, so making a shorty kit will not be an issue!! i have my own CNC machine shop I already have it mapped out!
brushless hobbies esc's are great! I've run the 120 in my scte for a couple of months now and havent had a single issue. I'll be following this thread and decide if i sell the sc10 4x4 and the scte
please report on durability.ts2 and tco2t front kickup plate breaks cant't push limit do to need to finish.kevlar was worse than original carbon fiber seems better but am driving more careful have broke 6 kickup plates 2on tco2t and 4on ts2.my t8e has been good so far.hope ts4 tobe just as durable as t8e.
