TeamC TS4-TS4Pro SC thread
#17
Where I would be running, the track is on smaller size and it gets rough driving.Would I be able to bang with the losi's and servive?This class is growing here.Looks like a blast to run.Always had tobe different from the rest.What esc and motor would be best for this class?
#18
Matt
#19
the losi's at our track all ran 1/8 esc would an orionr10pro handle these 4pole 550 motors?As I already have one to use.
#21
The pistons that come in the kit are the same ones that come with the 2wd and 4wd buggies and are too small for the truck, so the rebound is really slow so right off the bat you need to drill them out bigger than what they are. I will have 4,5 and 6 hole 2 stages ready by the weekend to test.
Overall i give the Kit and A+
and the performance a B, and thats because the 550CST small piston size ,soft spring combo flat out is not going to work out of the box but is easy to fix!
So the information that we need to gather is:
What wheels fit
What springs fit
#22
#23
please report on durability.ts2 and tco2t front kickup plate breaks cant't push limit do to need to finish.kevlar was worse than original carbon fiber seems better but am driving more careful have broke 6 kickup plates 2on tco2t and 4on ts2.my t8e has been good so far.hope ts4 tobe just as durable as t8e.
#24
#28
Ran my new TS4-PR yesterday. Had a push in the first heat so started wiorking to get the front to bite more. I was running the front small spring and the BB hard spring in front. That combo doesn't let the front ride heighth get low enough. So for the main I just ran the hard front spring and the front had tons of traction but then the rear was lose. Need to find a happy med in there. Over all even with some set-up still to do I was a 1/2 second faster with the Team C truck then I was with my SC10 4x4.
Over all very pleased with the truck and I'm looking forward to next weekend to see if I can get it dailed in even better.
#29
#30
My set-up
Front hard BB spring with stock piston and #45 oil
Rear small helper spring and option BB spring with stock piston and #40 oil
Differentials 7000, 5000, 3000
Just wrote Roy and having him send me some pistons to drill and experiment with hole size and oil.
