TeamC TS4-TS4Pro SC thread
#1201
Lol that's now my buddies truck. from what I can guess (it was converted when he got it) It moves the weight more to the front / Balanced. But it also raises the center of gravity which is causing some traction rolling. Also it's a bit narrow compared to other current SC trucks.
#1202
Are there still sources for parts for this truck? I still have mine although the class is pretty much non-existent here. But, I like the truck and want to keep it RTR and in good repair!
#1203
Team c had almost all the parts available now https://teamcusa.us
QUOTE=freezeframe007;15027636]Are there still sources for parts for this truck? I still have mine although the class is pretty much non-existent here. But, I like the truck and want to keep it RTR and in good repair![/QUOTE]
#1204
Hi, and greetings from a new member from Finland!
I'm fairly new to the hobby and don't know much about setups, although I have a couple of rc-cars already. However, I recently got my hands on a lightly used TS4TE (like new condition). The car is currently in full box setup as per manual including diff oils 30/30/10 and #500 shock oil all round and stock medium springs. Camber is set to -1 all round and toe is out 1. Having now tested it a couple of times on local indoor track, which is a concrete surfaced, medium grip 1/10-track with fairly small jumps, I have some issues regarding setup:
1. The car feels very unstable and twitchy driving straigth line and is very sensitive to steering input. I had to limit steering by a lot from my radio to make it somewhat drivable. -> How to calm down the steering and make it easier to drive?
2. It has a lot of oversteer when braking and generally off power. It seems to want to spin out very easily on higher speed turns. -> How to make the car to understeer a bit rather then oversteer in order to make it easier to control?
Any input/advice would be highly appreciated.
#1206
^ Thanks bobf24! I will try front toe in. Camber links are already inner hole. As far as I know rear toe adjustment is not possible on this truck.
