TLR 22SCT Thread (Check First Page for FAQ & INFO)
#8671
Forgive me if this has already been covered, but this is my first time looking at this thread in a long time.
Just noticed that Stormer and Amain both dropped their prices on this kit to below $200. Are they dumping them in anticipation of receiving 2.0 sct's coming out soon?
TLR is probably going to focus more on the 22-4
#8672
#8675
I ran the gear diff for the first time last Saturday with 5,000. I felt it had a little too much on power steering so I am going with 3,000 tomorrow night (anyone - if that is not the correct change, please let me as that is what I read).
#8677
The shafts are necessarily needed. From what they have said the new coating is more durable, but doesn't perform much different.
#8680
I built my shocks up with the new parts and stock shafts. Had a little leaking after running them some. Put the new shafts in and no leaking.
Also rebuilt my MIP puck diff with a Casper thrust kit. Didn't get to run it yet, but was able to really tighten it up and still be smooth. I left the MIP washer closest to the diff in it and used the rest from Casper.
I am hoping my rebuilt diff will get my truck back to what it is. My truck was really good and then went south. Changed everything in it just about except for the chassis and servo.
I was hoping to see a 2.0 with bellcranks and updated arms.
#8681
The new diff gear i got is the updated one with the little nipples that keep the gear from wandering, very nice!
I just rebuilt my shocks with the new X-rings AND the Machined bushings.
all i can say, is that the shocks are awesome!
for those curious, the difference is that the new bushings kinda grip the shock shaft, so at full extension there is minimal side to side play of the shock shaft. very nice! and smooth. 1 full day of racing, and a pack or two of practice, and absolutely no leaks. period. a little wet around the bottom of the shock body, but i think thats partly until the seals get fully seated.
#8682
TLRacing
TiNi Shafts measure from 3.47-3.48mm. We updated the TiCN shafts to have a diameter of 3.50 +/-0.01, and all of the shafts I have measured myself have been 3.50. This little extra on the OD seems to help some although it is not ABSOLUTELY mandatory, it does help a little more.
#8683
Puck Diff and Driveshafts
I was wondering what people's thoughts were on the MIP Puck system. I normally run a 13.5 in my truck and I knew that the system says it is rated for a 17.5. My drive cups are starting to develop a little bit of wear so I was debating upgrading to the PUCK system. This brings me to my next question. Can you replace the drive pins on the driveshafts? If you can how many of you replace the drivepins instead of buying new driveshafts everytime? This is another reason I was debating going to the PUCK system if it will hold up to the 13.5.
#8684
Ok have a question I have these shock shafts for a 22sct item numbers TLR233002 and TLR233000 These are the new TiCN shocks shaft but these shafts are shorter then the ones that come in the kit. Anyone have the right numbers
Thank You
Thank You
#8685
See attached picture, it is installed in my 22 2.0 buggy
