SC10 Thread Part 2
#2387
Hi, I did a search on this topic and didn't find anything. I need to get another SC body and thought I'ld try a lighter than average one. I know that this will most likely mean less durability, but I thought I'ld give it a try.
Are JConcept bodies generally .030 thick ? This would be on the thin side, correct? Is the JConcepts Raptor X-flow body a thin, light body? Any suggesstions?
#2389
Ultimate Android SC10 Tuning Guide
#2390
Having some handling issues I want to try and address with a new SC10. At the end of a straight I am having a spin or roll issue. This is on med to high bite clay running Bar Code type tires. Would this issue be a tire issue or ??? Tuning this truck is something I am new at and did not know which direction to start.
Using the Latest Maifield setup as my starting spot. Green Bar Codes front and rear.
Thanks-
Thanks-
#2391
"spin or roll", I dont know what that means. If you are rolling over onto your roof, lower your high height and you might also benefit from less droop in the rear. I added 1 limiter all around to my kids truck and it was way flatter to drive. With my truck on a higher bite track, I can never hit the turn at the end of the track at full speed. I always need to scrub some speed and set the truck up for the turn. You could also try to loosen up the rear to make the rear stick less and rotate better in the turn.
#2395
Thanks will give those items a try. The truck just cannot carry speed going into the corner coming off the straight. Really giving up time there as I have to let up sooner and coast the corner. I feel like it may be a tire issue and will start there with a less aggressive front tire.
#2396
#2397
What hole should the rear camber link be in on my A block? What are the benefits to a longer or shorter link? Will any of these help with on throttle turning coming out of a corner? Can't compete with these Losi's in that manner?
#2398
@joker to much to explain. Here is a good reading to get you started.
http://jq-products.com/the-news/43-t.../160-the-guide
and most people use the second hole from the inside on the A hub and C hub
#2399
so your spinning out on the high speed sections... what about the infield how is the car there in the turns?I k now for me when im coming down the straight and when i set up for the 90* off the straight i start high and kinda roll it off throttle alittle then get back on it and that works for me,i dont run drag brake on sc but do have my brakes set up like a abs system on a full size car.I have only ran my bb shocks one time so far,but my track was alittle inconsistant that night and i was running wishbones and rebars off and on. could depend on alot of things like tires/battery position/springs,oil,piston set up.
24Likes
