SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 03-12-2013 | 09:30 AM
  #3136
Suspended
I run the stock springs(silver up front green in the rear) and mine handles well...just my opinion
theblitzkidd is offline
Old 03-12-2013 | 02:56 PM
  #3137
Originally Posted by redrash
i have a problem im hoping you guys can help me with. i have a sc10ft. my current su is bb shocks, blue rr springs, 1.2 pist, 30 wt oil, 4th hole on the tower, outer hole on the arm, camber link is inner hole chassis, 2 washers, shaved brace, outer is all the way outside, ft bearing carriers with A block, front is yellow springs, 1.5 pist, 35 wt oil, outer hole on tower, outer hole on arm, camber link is inner hole tower, 2 washers, middle hole on c block. im running the battery all the way back, ballast weight under rr tower, and a rr sway bar. i set camber at 1° both frt and rr. the problem is, when i go into a corner, the inside rr wheel lifts off the ground and of course all the power is tranfered to it and i cant get out of the corner till the truck settles down. it doesnt matter if i go slow into a corner, or hard. but the harder i go in, the more the tire lifts off the ground. i set mine up just like one of the faster locals, and it still did it. his truck stays much flatter than mine, and he can drive thru the corner. my current su is from me trying different things.
its very frustrating watching everybody else drive by me, while my tire is in the air spinning away!! any suggestions?
it sound like you need a sway bar on the front or take the one off in the rear!!!!
gatorage is offline
Old 03-12-2013 | 03:25 PM
  #3138
Nicholas Muelle's Avatar
Originally Posted by Chamelion
Anyone else had issue with diff thrust bolts snapping en mass? I'm getting sick to death of it happening.
I had the same thing happen to me about 5 times. I sent it in with an email to Team Associated and they sent me a new diff rebuild which included the entire diff.
Nicholas Muelle is offline
Old 03-12-2013 | 03:58 PM
  #3139
Whew! I got worn out reading about all those adjustments.
shagnat is offline
Old 03-12-2013 | 04:00 PM
  #3140
mxracer458's Avatar
I have a brand new set of green double dees mounted on 12mm hex wheels for sale,40shipped
mxracer458 is offline
Old 03-13-2013 | 09:44 AM
  #3141
???E-Racer's Avatar
The red fronts and grey rears are working for me. With 40wt shock oil.
Of course im running the factory team kit. Alot of people run 40wt outdoors.
30wt seems about right for indoors. As what my kit came with.
I have not had any durability issues yet. Truck has been ran twice on two
different indoor tracks.
???E-Racer is offline
Old 03-13-2013 | 12:22 PM
  #3142
Cptn Cartwheel's Avatar
Default new arms and towers
Normally, going out on the tower results in less traction. With these new towers we're going out far past any setting previously available with seemingly no loss in steering. How does this happen? Does it have something to do with lowering the mount on the arms and the "gullwing" design? You get to keep all your steering, it increases stability and you dont need a swaybar anymore, but why? The same thing happened on the 1/8th scale, and many other vehicles have the same type of layout now, like the Losi 22. Just wondering from a design and engineering point how this works better and why. Thanks in advance for any facts, or opinions.
Cptn Cartwheel is offline
Old 03-13-2013 | 03:20 PM
  #3143
Has there been any rumors as to when the updated SC10 will be out? Just wondering if I sould wait for the AE offering or go with brand L.
65BAJA is offline
Old 03-13-2013 | 05:02 PM
  #3144
+1 for that, I heard it was a week, then months, then days, and so on....
Old 03-13-2013 | 06:56 PM
  #3145
mxracer458's Avatar
Originally Posted by longlivethe3
I am, they rub until you get the scissors out and make them not rub
how bad did they run the stock body?do they stick out past the fender line?I need some for this saturday but i dont want to hack up a nice painted body
Old 03-14-2013 | 07:05 AM
  #3146
I run the stock body with hazzards and did no trimming.... If you have to trim, it is minimal and you wont even notice.
Bubonic-X is offline
Old 03-14-2013 | 07:19 AM
  #3147
Default Tire help
Just bought a new FT SC10. I am needing some tire suggestions.
First track is an indoor clay high bite track.
Next is an outdoor track, low to medium bite track. What tires so you guys suggest
Jason
Blues Hockey is offline
Old 03-14-2013 | 07:26 AM
  #3148
mxracer458's Avatar
Jason
Any clay type bar tire will work,for out doors depends on track surface I have brand new double dees mounted if your intrested
Old 03-14-2013 | 07:27 AM
  #3149
matt*strike's Avatar
Jason
Most of the guys at the track will tell you what is best to run there. I would ask the guy who finishes first most of the time at either track I'm sure they will tell you what tires they have.
matt*strike is offline
Old 03-14-2013 | 09:27 AM
  #3150
Jason
Normally just check with your local track due to varying conditions. There really isnt a be all tire, although some tend to work better than others at most places.
ritojr is offline
