SC10 Thread Part 2
#1636
Hey guys, a few quick questions. I spent the summer focusing on my RC8 nitro buggy. I raced my SC10, but I didn't really focus on it much, I just ran it as is with the few upgrades I did in the spring. Now that winter is knocking, I plan on racing at a local indoor track. I started throwing a few more upgrades at my SC10 and I was wondering if I am missing any essential upgrades. I started with an SC10RS. I have an arsenal of wheels and tires. I put in a Brushless Hobbies 120a esc and Tekin Redline 7.5t 6100kv sensored motor. J Concepts aluminum steering rack, and rear aluminum hubs. Spring kits front and rear. Solar D770 servo. (I have a Savox 1256TG in my buggy that I am considering stealing for the winter). I have a handful of spur gears and pinions. I have a few different bodies. Am I missing anything essential? Thanks guys.
#1637
you bought a used truck and we have no idea what the overall condition is. A worn sc10 will have slop in it. If you have a lot of slop in the rear check the bearing and make sure the crush tube is in there. Make sure the wheels are tight but still spin freely. I would assume that the truck is well worn, and I doubt the alum rack or hexes will help much. It is in your best interest to break down the truck. Download the manual from AE and break it down. Check for stripped screws, missing parts, bad bearings, broken parts and ensure the truck is properly assembled. I do this with every used truck I buy. Unless you bought it from a racer that kept it well maintained, chances are it is all jacked up.
So when you grap you wheels there is no movement what so ever? No wiggle at all??
#1638
The solar d770 is fine. All of your stuff is fine. Just fine a good setup for your dirt, carpet or AstroTurf track. If you dont have Titanium turnbuckles, you might want to get a set. I prefer Lundfords for the lifetime warranty. I bent a few and 8 year later I mailed them back and they sent me new ones. Didnt even need a receipt. You might want some lead weight also for your setup. I prefer the RPM front bumper. It has a nice skid plate to save your chassis and it performs better imo.
#1639
More droop means the truck will handle jumps and bumps better.
Just as important as ride height in my opinion.
If I have a few droop gage sets made (5, 7, 9 deg front and rear) is anyone interested in buying for $15-$20/set? Avail in a few weeks.
PM me if interested.
#1640
there is be some wiggle. the bearings have play in them and the suspension will have some play. At some point it becomes excessive. Make a video, lol. Much easier to tell from a video if it is bad or not.
#1641
weight is used to eigther even out the left to right weight or move the weight forward or back for the desired traction. The "common" setup is battery forward and 3oz weight under the rear battery foam. People without weight, often start out with the battery back. and move it forward as needed.
#1642
The wiggle is not excessive...but it is there a small bit...the real problem I see on both trucks is the steering racks which are stock...the Blitz is real bad...the SC not to bad...Can't wait to get the new bell cranks!! Thanks for Help and to a great thread!
The weight thing is a little more confusing...I thought using heavier springs in the from was a good way to get more traction in the back.
Do I look for skidding around corners or bad traction when accelerating to add weight in one area or another?
#1643
#1644
No bueno if you are trying to use the C hub, but beggars can't be choosers.
#1645
Another question I have was answered during this thread but I forgot. If I have the alum rear hubs what bearing kit do I buy from avid also are the revolutions the best or rubber?
#1646
Having a couple questions. One i was told to remove my sway bar on indoor clay. Would anyone recommend using one and if so which one? Also i just have the shocks that come on the sc10rs currently. What do people consider to be the best shocks for this truck?
#1647
Can I see a picture for the 3oz of weight? Also do you mean all the way forward for the battery by battery forward?
#1649
Hey guys I hit the track today for some practice with the new setup (Tekin Redline 7.5 sensored and Brushless Hobbies 120a esc). Ran awesome. First time at this track and I was running consistent lap times with some of the best guys there. My motor/esc was running super cool. Motor barely broke 100 with a 22t pinion and 84t spur.(It was only about 50 degrees inside). Ran great the first two packs. I had an issue once I got to my third pack. I was be going down the straight and the power would die out and it would cut right. I would stop for a second and hit it again and I would have full power for a few seconds then it would do it again. When I check my lipo one cell was 4.01v and the other was 3.34v. Can I assume that the one cell is bad and under load it dropping way too low and the esc is cutting out? I always balance charge, and I always check my lipos voltage before I put it in the truck. Thanks guys.
#1650
sounds like a bad cell. when you balance charge it next time, I would watch it closely. No need for a fire. Check the cells to make sure they are the same and try again. if the cells get that far apart again, I would toss it.
24Likes
