SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 01-06-2013 | 05:51 PM
  #2356
20 SMOKE's Avatar
well i'm back to a SC10 after 9-10 month break,won it at the region 4 offroad championship so what better way to get back in.tq'd and won mod sc out of 15 or so.any one using the 4th hole in the shock tower
20 SMOKE is offline
Old 01-06-2013 | 06:00 PM
  #2357
Wildcat1971's Avatar
most people that race use the 4th hole yes.
Wildcat1971 is offline
Old 01-06-2013 | 06:20 PM
  #2358
20 SMOKE's Avatar
well i drilled it and will give it a shot
20 SMOKE is offline
Old 01-06-2013 | 07:41 PM
  #2359
mxracer458's Avatar
I've raced mine twice and it's a blast again,had to tell a kid in practice to chill out with the slamming but overall with the new bb and triad and peak 17.5 motor it's fast
mxracer458 is offline
Old 01-06-2013 | 08:09 PM
  #2360
Had a good long practice session today, finally with no breakage. I had put on the RPM bumper/skidplate and also added RPM ballcups with FT Ti turnbuckles all around, FT aluminum rear hubs, and FT shock bushings. Truck handled well, probably the best it has been so pretty happy with that. I did not notice any ill handling characteristics from adding the RPM front bumper kit.
Question: Does anyone know if I can run a 13.5t Revtech and Savox 1258TG with my stock (RTR RS kit) esc/rx? I am pretty sure the esc can handle sensored motors and I read I can use a BEC stabilizing capacitor for the servo. I'll upgrade the esc and radio eventually, just trying to see if I can get away with minimal $$ before going racing.
justinco is offline
Old 01-06-2013 | 09:43 PM
  #2361
Suspended
Default shock setups
hey guys.. im just getting into short course racing and im looking for help with suspension setups.. i am running a factory team sc10 2wd and need help setting up my suspension.. i have red, blue, silver, gold and green springs. which ones would i need to run for the front and rear for indoor dirt track? and what fluids should i use? i wouldnt say the track is loose dirt, more hard packed. any help would be greatly apreciated.. i cant seem to get it right.
Lemonbrisk is offline
Old 01-07-2013 | 05:11 AM
  #2362
jkach's Avatar
Go to the AE website and start with the Chad Due setup for trackside. That should get you where you need to be---to start.
jkach is offline
Old 01-07-2013 | 06:26 AM
  #2363
Suspended
Thanks jkach that helps..
Old 01-07-2013 | 12:22 PM
  #2364
mxracer458's Avatar
so i seen on the novak blog that people are using the sc10b front end on the t4.1 truck,i wonder how it work on the sc10?mounting the front body posts?
Old 01-07-2013 | 12:28 PM
  #2365
SinCityMedic's Avatar
Like this?....
SinCityMedic is offline
Old 01-07-2013 | 12:35 PM
  #2366
mxracer458's Avatar
Originally Posted by SinCityMedic
Like this?....
how does that body mount bolt up?did you have to redrill some holes?also any difference in handling between the two different front ends?i run on med bite indoor clay
  #2367
what advantages are you supposed to get with the SCB front end? Are they just using arms or something else?
Bob Barry is offline
Old 01-07-2013 | 03:17 PM
  #2368
Yes, had to drill two holes. One on either side of the center mounting point. If you notice the scb front shock tower has mounting points for the t4 front body posts. I am pretty sure the scb front shock tower and front arms will replace the current t4/sc10. As for handling characteristics... It is similar to the changes made to the rc8.2 the "worlds" front tower/arms if you will. By lowering the mounting point on the tower and the a arm it alters the geometry. I'm no physics major but I'm pretty sure it has to do with leverage. The end result is more stability and less twitch.
Old 01-07-2013 | 03:20 PM
  #2369
Matt Trimmings's Avatar
You need the Arms and Shock Tower. I was told (for the T4) that it helps prevent the truck from wanting to spin out coming off the straightaway. It helps to make the steering smoother. The person I talked to said that a few of the team guys were trying it but they hadnt put alot into it as of yet but that it did show promise.
Matt Trimmings is offline
Old 01-07-2013 | 03:39 PM
  #2370
mxracer458's Avatar
mattt,
thanks for the shock shaft!! bb on the sc10 are a huge plus and really helps the truck out,ae said they didnt have anymore but they sent me one and it arrived sat,go figure,i ended up tq and got 2nd in the main.Thanks again!
