Tekno RC EB48 Thread
R/C Tech Elite Member
After reading some of the posts about airflow I thought I would throw this out there.
My Tekin 2050 was getting warmer than I wanted with the pinion I wanted to run at first. I simply opened up the two forward facing air scoops on the right side of the stock body and it allowed enough air in to drop my temps. If I remember right, I saw about 20 degrees of temp drop.
Just in case someone hasn't thought about it.
-Chris
-Chris
-Chris
-Chris
Can a MOD please add this as a sticky to the front of EVERY Tekno thread? I just made a list of all the screws, washers and nuts needed to convert a Tekno ride over to all aluminum screws. I listed the stock replacement Tekno screw part number first with details beside each. Only screws I did not list for an aluminum swap are the diff screws holding the ring/spur on to the diff. That's a high load bearing screw and steel is a better choice there.
Tekno Screw List:
Tekno #1523 3x10mm Flat Head 2
Tekno #1529 3x20mm Cap Head 20
Tekno #1341 4x6mm Flat Head 6
Tekno #1525 3x14mm Cap Head 18
Tekno #1524 3x12mm Cap Head 10
Tekno #1333 3x40mm Flat Head 4
Tekno #1327 3x16mm Flat Head 4
Tekno #1443 4x10mm Button Head 11
Tekno #1522 3x8mm Cap Head 9
Tekno #1445 4x14mm Button Head 6
Tekno #1447 4x16mm Button Head 2
Tekno #1401 3x6mm Button Head 8
Tekno #1448 4x18mm Button Head 2
Tekno #1343 4x10mm Flat Head 12
Tekno #1322 3x8mm Flat Head 11
Tekno #1344 4x12mm Flat Head 12
Tekno #1346 4x15mm Flat Head 2
Tekno #1325 3x14mm Flat Head 3
Tekno #1407 3x16mm Button Head 1
3x8mm Washer 20
4x9mm Washer 2
3mm Locknuts 20
3mm Flanged Locknuts 8
Tekno Screw List:
3x8mm Washer 20
4x9mm Washer 2
3mm Locknuts 20
MODS PLEASE ADD THIS AS WELL.
Part list for all the Tekno screws cross referenced over to blue aluminum at Fastenerexpress.com:
Only thing not listed are the washers.
M3 x .5 x 8mm Socket Head Cap Screws - Blue Qty. 25
Item Number: 30968
$6.01
M3 x .5 x 12mm Socket Head Cap Screws - Blue Qty. 25
Item Number: 30974
$6.47
M3 x .5 x 20mm Socket Head Cap Screws - Blue Qty. 25
Item Number: 30989
$7.51
M3 x .5 x 16mm Button Head Socket Screws - Blue Anodized Qty. 25
Item Number: 30671
$6.82
M3 x .5 x 6mm Flat Head Socket Screws - Blue Qty. 25
Item Number: 30750
$5.78
M3 x .5 x 10mm Flat Head Socket Screws - Blue Qty. 25
Item Number: 30756
$6.24
M3 x .5 x 16mm Flat Head Socket Screws - Blue Qty. 25
Item Number: 30765
$6.82
M4 x .7 x 10mm Button Head Socket Screws - Blue Anodized Qty. 25
Item Number: 30604
$8.44
M4 x .7 x 14mm Button Head Socket Screws - Blue Anodized Qty. 25
Item Number: 30610
$9.59
M4 x .7 x 16mm Button Head Socket Screws - Blue Anodized Qty. 25
Item Number: 30613
$10.16
M4 x .7 x 18mm Button Head Socket Screws - Blue Anodized 25 Pieces
Item Number: 30622
$10.75
M4 x .7 x 10mm Flat Head Socket Screws - Blue Qty. 25
Item Number: 30717
$7.51
M4 x .7 x 12mm Flat Head Socket Screws - Blue Qty. 25
Item Number: 30720
$7.98
M4 x .7 x 14mm Flat Head Socket Screws - Blue Qty. 25
Item Number: 30723
$8.44
M4 x .7 x 6mm Flat Head Socket Screws - Blue Qty. 25
Item Number: 30711
$11.21
3mm Hex Lock Nut Aluminum,Low Profile 5.5mm Hex - Blue Qty. 25
Item Number: 30147
$14.09
M3 x .5 x 14mm Socket Head Cap Screws - Blue Qty. 25
Item Number: 30977
$6.57
M3 x .4 x 6mm Button Head Socket Screws - Blue Anodized Qty. 25
Item Number: 30646
$5.78
M3 x .5 x 14mm Flat Head Socket Screws - Blue Qty. 25
Item Number: 90193
$6.70
Total with all screws having a count of 25 is $160.38
Item Number: 30968
$6.01
Item Number: 30974
$6.47
Item Number: 30989
$7.51
Item Number: 30671
$6.82
Item Number: 30750
$5.78
Item Number: 30756
$6.24
Item Number: 30765
$6.82
Item Number: 30604
$8.44
Item Number: 30610
$9.59
Item Number: 30613
$10.16
Item Number: 30622
$10.75
Item Number: 30717
$7.51
Item Number: 30720
$7.98
Item Number: 30723
$8.44
Item Number: 30711
$11.21
Item Number: 30147
$14.09
Item Number: 30977
$6.57
Item Number: 30646
$5.78
Item Number: 90193
$6.70
I wouldn't recommend using aluminum screws everywhere. They are just plain ole too soft.
I actually wouldn't recommend using the aluminum screws at all unless you have high quality wrenches (mip) and know the car well. Its hard to stress how soft aluminum is.
Yeah I'll pass on the aluminum screws. I have used them before and they snap easy. And Redbeard is right you have to have good set of wrenches or they strip. Actually they will strip anyway if you over tighten them.
2Likes
