Tekno RC EB48 Thread >
Like Tree2Likes
Old 01-10-2015 | 04:08 PM
  #14101
idbdoug's Avatar
Is the HOBBYWING Xerun SCT Pro ecs a good choice for EB48.2? I would prefer it over the Xerun 150A SD because SCT Pro is smaller
Thanks for your input
idbdoug
idbdoug is offline
Old 01-10-2015 | 05:28 PM
  #14102
Suspended
The SCT pro is an awesome ESC. You won't be disappointed.
MattP is offline
Old 01-10-2015 | 08:38 PM
  #14103
idbdoug's Avatar
idbdoug
idbdoug is offline
Old 01-10-2015 | 08:40 PM
  #14104
FastPete's Avatar
idbdoug
Same one I use in my EB you will love it.
FastPete is offline
Old 01-10-2015 | 08:42 PM
  #14105
FastPete's Avatar
Originally Posted by nitroceciljr
Hey guys, just bought a new Tekno, excited to get this bad boy on the track! I’ve read through the first page so I’m good there. Just wondering if there is anything I need to know while going into this build? Any extra tips or tricks? Also, for you indoor guys, are you running 7k/7k/5k or should I just go ahead and drop to 3 or 2 in the rear? Thanks!
Indoor im using 755 might try 753
FastPete is offline
Old 01-11-2015 | 06:28 AM
  #14106
What pistons are we using now?
dhickman is offline
Old 01-11-2015 | 06:29 AM
  #14107
Never mind found it!
dhickman is offline
Old 01-11-2015 | 06:30 AM
  #14108
Anyone using the new shock spring perches?
dhickman is offline
Old 01-11-2015 | 08:33 AM
  #14109
Yes, seem to work very well. We'll see how long the boots hold up. It seems like they were sold as significantly thicker, which I really don't think is the case. It is indeed thicker, but not as thick as I had imagined. Hopefully they do well long term. I also found it's much easier in my opinion to remove the piston and put the new boot on this way vs unscrewing the shock end if you're rebuilding the shocks anyway.
RokleM is offline
Old 01-11-2015 | 08:38 AM
  #14110
Think ill order them with the new boots
dhickman is offline
Old 01-11-2015 | 08:44 AM
  #14111
The new ones aren't made to run the old boots. You might be able to figure a way to get it done, but they're really designed to work together, so yes.
RokleM is offline
Old 01-11-2015 | 09:10 AM
  #14112
Ya the bottom of the old boot is probably too thin!
dhickman is offline
Old 01-11-2015 | 09:14 AM
  #14113
You got to love tekno for developing parts for this car, think I'll get the new center shaft, droop screws too!
dhickman is offline
Old 01-11-2015 | 09:17 AM
  #14114
The droop screws are a minor change but huge convenience factor. Definitely worth every penny.
RokleM is offline
Old 01-11-2015 | 12:43 PM
  #14115
FastPete's Avatar
6x1.5, the perches work great and fit like a glove. I just put them on after one popping up.
FastPete is offline
