Tekno RC EB48 Thread >
Like Tree2Likes
Old 09-06-2014 | 06:29 AM
  #13456
Afun's Avatar
My Favorite Ebuggy EB48.1...bought at launch...regret letting this one go
Tek 1 by Afun2011, on Flickr
Afun is offline
Old 09-06-2014 | 07:01 AM
  #13457
Cain's Avatar
Tech Legend
yeah I would regret that too!
Still rocking the EB48.1 I have. quality of tekno stuff is that still holding up excellent and just upgrade as needed.
Cain is offline
Old 09-06-2014 | 08:18 AM
  #13458
ironzgti35's Avatar
What is the opinion on the carbon towers? Strong enough to take a hit or not worth the investment?
ironzgti35 is offline
Old 09-06-2014 | 08:25 AM
  #13459
FastPete's Avatar
That's a tough call, I ran them on my EB48.2, and started a crack in the front one. My fault from crashing. But I also broke a stock one. Again a hard hit. What I see is a good driver will run that kinda stuff with success. Don't hit stuff like myself. Its your call.
FastPete is offline
Old 09-06-2014 | 08:55 AM
  #13460
Hey guys
Looking for some advice ... so ran the car properly this evening for the first time. Setup is based off this one - http://www.teknorc.com/tekno5/wp-con...EDIUM_BITE.pdf
Although I am using Kyosho blues all around and also the stock ARBs (I do have the 15 carriers and the LRC). Car is nice! Running 2050kV on a 17T pinion and temps are around 190 ... it's ok I guess.
But I just think the rear end is a bit too planted ... I can get around the track in a reasonable time, but I just cant help but think that if I could get the rear to rotate a bit more quickly, I would be happier.
Tyres are Proline Blockade M4s and track is medium grip indoor loamy clay. Also running stock pistons ... Maybe I need to make a change there? Also middle and rear braces are off.
http://youtu.be/0-S-F2oaBUA
Particular bits I'm having issues with is the sharp left hand at the end of the short pit straight and also the 2nd left hander after the series of jumps in the middle of the course. Quickest way around that is to make the jump off the 1st left hander turn right straight away. I seem to be staring the face of the pipe a lot despite landing well.
WagwanBumba is offline
Old 09-06-2014 | 09:58 AM
  #13461
mkl
I might try the stock 10* carriers. I think they might help the front turn better. I would think that you might want to keep the rear planted and make the front more aggressive. Somebody can correct me though, I'm no expert.
Lots of comments also that the LRC block makes the rear very planted. Maybe try the regular 1.5 block.
mkl is offline
Old 09-06-2014 | 10:09 AM
  #13462
Cain's Avatar
Tech Legend
have you thought of less toe in and / or raising the rear link on the tower?
Cain is offline
Old 09-06-2014 | 11:48 AM
  #13463
Does anyone run the shock collars without the o ring? Noticed that 2 shocks are spinning the body out of the cap when trying to adjust the collars since there so tight. Any way to loosen them up out then spinning them off and on the body a dozen times?
Originally Posted by ehartman_49348
Put some shock oil on the o-rings before installing them.
Shock oil will work, but for a more long term solution use green slime. Get the o-ring lubed up and put just a slight amount on the body when you're threading it. Makes it MUCH easier.
RokleM is offline
Old 09-06-2014 | 12:42 PM
  #13464
ironzgti35's Avatar
Does the .2 come with angled gear boxes for front and back?
Old 09-06-2014 | 01:24 PM
  #13465
suzukipro's Avatar
Post
I decided to upgrade my shock bodies to the newer style that allow for the stepped upper shock guide to be used, in my case for the new delrin guides. The ones that I received have a lighter color anodizing than my original EB-48.1 shock bodies, but still have the smaller diameter shock shaft hole . I did some homework and found that there wasn't a running Part number change, I ended up drilling them out so they now fit the new guides, anyone else encounter this situation?
suzukipro is offline
Old 09-06-2014 | 07:33 PM
  #13466
Originally Posted by WagwanBumba
Hey guys
I am definately not an expert but I would say that the car actually doesnt look that bad. I would say throttle control. It wasn't too bad. It handled some of the turns excellant. Only pushed out when you came in too hot. I personally like the 8 x 1.3 pistons and stock springs.
rythby is offline
Old 09-07-2014 | 04:08 AM
  #13467
Ahhhh that was me running my car. That was just a video I found of the track in its current layout. If I have issues again, I'll try get it video'd
Old 09-07-2014 | 06:54 AM
  #13468
I would try less rear toe
one8updragracer is offline
Old 09-07-2014 | 11:33 AM
  #13469
ThreatRacing's Avatar
Going to pick up a Tekin T8 Gen2 motor. What KV rating do you guys recommend for the EB48? Going to be running 99% outdoor so I was thinking a 2050 or 1950?
ThreatRacing is offline
Old 09-07-2014 | 11:40 AM
  #13470
1900! The 1900 is more than enough on a big outdoor track, especially for a vehicle as light as the EB48. I've tried the 2050 motor and it's not nearly as smooth off the bottom as the 1900.
Wease is offline
