Tekno RC EB48 Thread
#9481
For anyone looking to shave some weight with aluminum screws, check out Fastener Express...They have regular and anodized selections in just about every size you would need...Anodized colors are blue, purple, red, and black for that stealth factory steel look...
#9482
How has balance been when you run heavy packs?
Right now, I want to kind of wait and see how things go for next years battery selection, but, I do have promatchs 7200mah packs in 2S config, I figure if an event comes up that I need some batts, I can just that nice adapter male to male plug they have and run those.
#9483
The parts tree still has the .1 inserts you can use, but the updated insert is better.
#9485
anyone know where to get a list of all the screws in the eb and sct?
#9487
There was on a couple pages back.
Its really not that hard, its just tough to explain in text. Take the pivot ball (TKR5052) out of the steering link rod end on the hub side and flip it upside down. There is a big flange and a small flange. Stock is big flange down (resting on hub), you want big flange up. Also don't forget to re-situate the washers also (4 on top on hub side, 4 on bottom on Ackerman plate side).
#9488
I did the other mods, but I still have 2 washers on top and bottom both at the hubs and the ackerman plate.
#9489
#9490
As for the effects heres the notes from Hudy:
Bump steer is a front suspension tuning option commonly used in off-road RC racing to change steering characteristics over rough and loose terrain. Bump steer occurs when a car’s front toe angle changes as the suspension compresses or rebounds, which affects how parallel the front wheels are.
More bump steer(wheels more parallel under compression)
- Increases steering in mid-corner
- Steering may become “twitchy”
- Easier to control on smooth tracks
Less bump steer (wheels open more under compression)
- Decreases steering in mid-corner
- Smoother steering response
- Better on rough or bumpy tracks
HOW TO ADJUST:
More bump steer = Steering rod becomes more angled (away from horizontal)
Less bump steer = Steering rod becomes more horizontal
#9491
Here's a quick question on rear camber link, cause I think I confused my self... LOL
The backend washes out sometimes when i get on power from exiting a corner. I'm wondering if it's cause I have too light of a 4s Lipo (13oz) and my typical 4s is 17oz.
My first thought is to maybe try without the Rear Chassis Brace.
To help plant it a little better, would I lower the rear camber link on tower to the lower inside hole.... or raise one hole on tower??
I currently have the rear hub sitting in the middle of arm.
Camber link sitting Middle Inside on tower and "C" on Hub, Lower hub hinge pin is outer hole.
DIFFs are 7-7-4
Track is smooth hard pack clay
DIFFs are 7-7-4
#9494
If you want more bump steer my suggestion would be to flip the pillow ball on ankerman side aswell low side touching ankerman plate with 4 washers under high side of pillow ball
This will increase the angle of steering link futher again with the mod on the hub side aswell
2Likes
