Tekno RC EB48 Thread
#6272
Did what cain recommended and put 2K in the rear diff. Has a ton of grip, no sliding at all, and still has plenty of steering (a little too much). On my hardpacked, loose, bumpy outdoor track, my car was hooked up. Really liked it, and i think i'll set my front toe out to zero, instead of the .5 it's at now to get a little less rotation.
#6273
#6275
In my experiences the extra tough arms are not nearly tough enough...I'm going through these quicker than a roll of toilet paper...up to 3 broken front arms, over 4 race days. Not only breaking the arms, but bending hinge pins in the process...i hope it was just a bad batch but that's probably wishful thinking...ughhh.
#6276
Man Bort, you must be pretty rough on them.
I beat on my car like a rented mule and the only time I've broken anything was from hitting the end of a pipe off landing a triple.
#6277
#6279
I've been running in 40-60 degree (F) weather thus far this season. Not hitting the pipe a lot, but I have shorted some big jumps. What could cause the inner hinge pin to rip through the A-arm? I've made sure my hinge pins holders are tightly secured to the diff housing.
Just messing with ya! I haven't tried the HD arms I'm still on my original kits from a year ago as well. Seems like an odd number of failures in your case.
#6280
#6283
I think 2K Rear is going to be my starting setting for both my SCT410 and EB48.
What did you settle on for Front and Center diff fluids?
From what I recall last time talking to them they were going to continue with the V1 a-arms. Personally I hope they change there mind not so much from the position of beefier arms, but the different shock mounting locations on them.
#6284
This might have been answered elsewhere in the thread but I don't remember seeing it:
Why are the Tekno rear springs so light compared to the other manufacture's rears??? The stiffest Tekno rear (red) is 2.93 and the Kyosho's start at 2.95 and go up. I'm trying to decide what spring package to use to tune.
Also, are the Associated Rc8 8 hole tapered 1.3's (ASC89459) very different from the Kyosho white 8 1.3's ? I haven't seen anyone mention this as a viable alternative to the Kyosho's. Why?
Love this buggy!!! Went to huge tri-state race (50 E bugies) and a lot of fast guys there and qualified 6th in the A. Almost all of the A main drivers were sponsored drivers.
#6285
2Likes
