Tekno RC EB48 Thread
#6242
It is all in setup. I get the same comments at my local track. I let people try my car so they can see it for themselves. The car will roll more than anything available because it is so narrow. If you reduce the roll to be similar to other cars, it will yield similar traction but due to the fact that the weight placement of the tekno, it changes directions more quickly and is more predictable. I have run many cars, when this car is set up right, there is nothing out there that compares. It just requires you to think outside the box. It doesnt like to be setup like most cars.
http://www.youtube.com/watch?v=1xVArNvRoZo&sns=em
#6243
I run in the tampa area so the warm weather is a concern for me with shock oils. I know that the shock oils are not supposed to thin out with heat but they do. In the warm weather i bump up my oils by 5 wt. This past weekend i tried a new approach with springs and i was pleasantly surprised. Lighter spring and heavier sway bars made the car much better. The car generates much more traction. The heavier bars keep the car from over rolling. The outer hole on the arms for shock mounting have also become my new best friend.
I also went stiffer with spring when i started with this car. It was good but no way near like it was this weekend.
#6244
Go up about 15wt and try lighter springs .
#6245
Based on what you are seeing, definitely sounds like you need more pack to me at least.
#6246
With the stock pistons I needed 40/32.5 to keep the car from slapping with the 10x1.2 pistons.
The kit springs aren't bad, but the Kyosho's feel better. Combined with the 8x1.3 pistons they will support the car better landing jumps.
#6247
All oils will thin out with increased temperatures. The silicon oils just thin out at a slower rate than other types.
I'm with you on the softer springs and stiffer sway bars. They resurfaced and sugared our track last week. I had to stand up the rear shocks one hole on the tower, go to a medium tire, and put stiffer sway bars on my car to keep it right side up.
#6248
They definitely are angled. What's the pro/con to that?
#6251
The black pistons are made for smoother tracks. Found this quote in the Inferno MP9 thread:
"The stock angled pistons are really made for smooth tracks with bigger jumps, that need alot of pack and little rebound."
Another:
"White is tapered with straight holes.
Black is tapered with holes drilled at a 45 degree angle.
Get the whites. Black slow down the shock compression and rebound since the holes are drilled at an angle. I have a set of both and I didn't like the black pistons when I tried them. They would probably work better for fast smooth tracks."
Another:
#6252
Guys, I cant see setup sheets on my Ipad and I am about to place a small parts order. What sway bars come on the car and what have most found to be the sweet spot? Reading the posts on this page seems some are having luck, at least on high bite surfaces, going lighter on spring and heavier on sway bars.
As for pistons, are any of you running the Fioroni 16mm versions?
#6253
The car cones with the 2.3 and 2.4mm sway bars. Depending on the conditions I've used 2.2 to 2.8.
#6254
The nice thing about this car is that the front and rear sway bars are the same. So if you buy one of each you pretty much have every scenario covered. No need for a full set of both front and rear like some other cars.
#6255
Also, Laying the shock down also helps with big jump slapping as it is harder to compress from a landing than a more vertical shock. A layed down shock will make the car roll easier in the corners. This is why I increase the sway bar thickness so the car doesnt feel mushy in the corners.
This past weekend I ran Tekno green springs front and rear with 2.5mm sway bars front and rear. I ran 45 wt. front oil and 35 wt. rear oil with the stock pistons. Alot of guys at the track complained of loose cars but mine was great. Tons of steering and rear grip. I qualified 3rd overall out of 28 cars. This is in a field of stiff comp also.
I am looking forward to trying Kyosho pistons. I want to run 8x1.3mm.
2Likes
