RC10B4/T4 Forum
Dave that other stuff is not the same green color is it ?
So why tell others it is the same as green slime ?
Profit margins ?
Whats that have to do with shocks ?
Profit margins ?
So where do you actually put the green slime when rebuilding the shocks and how much of it? Thanks
Sounds good. Thanks.
Also for everyone out there, as I am getting to be a better driver and focusing more on set-up. How often do people rebuild the AE shocks? Do you just change the oil sometimes or always rebuild the whole thing? Please don't turn this into a shock bash-fest about which brand is better. Just a simple answer is appreciated.
I refresh my shock oil every other club race ....( about every 10 runs)
I change the seals every 2 weeks...
All these posts about shock seals -- just move your front/rear up and down and observe if/how it settles/sticks when just rebuilt and use that as a reference for checking later if your shocks are sticking more. When in good condition, you should see things want to return to nearly the same point regardless of if you pushed the car down and let it raise on its own or let it settle down from above ride height (or from a light drop of a small distance). Obviously it's going to have some stick to it and the springs you use will change this behavior, but you can use what it does when freshly rebuilt as a reference to tell later when you're wandering away from like-new condition and by how much.
The rear of my b4 is terribly in need of new seals and it is quite pronounced in its willingness to stick a little. Having said that, I TQ'd with it last time I ran it like that so your mileage may vary on how much of an impact it has on you, but you can at least be aware of it.
Has anyone tried using powdered graphite lubricant on the transmission gears? Is it even needed?
How come they don't make RPM arms for the B4? Am I wrong on this? I swear by them on my T4 and was curious. Thanks in advance.
DO you really use that much of it? Mine had lasted over 2 years. OK, I don,t race as much as many here, but unless you are tearing down and rebuilding your diff every race, I think your 4$ tube will last a good while... Now the green slime is another story especially since people seem to be rebuilding their shock frequently...
Just my 0.02$
Just my 0.02$
Yep..why spend $4 on a few grams when you can spend $8 on a few ounces. Makes sense.
RPM is a stickler when it comes to building things right. If they don't think they can't make it indestructible and turn a reasonable profit then the won't make them. I think the driving force between the two is the T4 arms also fit the SC10 and the GT2.
Ahhh... If you're sharing your personal lubricant then it makes sense to order more of it... Just kidding! But I see why you want a bigger jar of it.
