Serpent 811E Buggy Thread >
Like Tree5Likes
Old 11-18-2011 | 03:03 PM
  #691
KIK's Avatar
KIK
Originally Posted by taztal3
porkchop-did you run your buggy yet ? how you feel team orion speed control /motor ?
I just talked to him today and he's still waiting on a part.
KIK is offline
Old 11-19-2011 | 05:47 PM
  #692
Default servo horn
well... my stock servo horn just striped. any alum replacement that will work?
thanks
psionic is offline
Old 11-19-2011 | 06:46 PM
  #693
Originally Posted by Frank L
This car has gone together like a glove. The only thing I had to hunt for was the shims behind the sun gears in the center diff. I found them in the front/ rear diff bag. It has +2 hubs and the shock towers are the same. Chassis braces are not. I'm making a list of the hop ups that are avail from the buggy that work. Alum steering servo horn is a bit tricky but with a countersunk washer and a couple of the serpet conical washers i got an alum horn to bolt up. I have about 6 hours into it and here's what it looks like. Just shocks and electronics left. Work of art is right. One pleased racer here. Have to get it dirty on sat.
Racers Edge horns work, Frank L shows how to do it. Play with the servo spacing on the mount to make sure it clears the radio tray and clears the front chassis brace when its installed. Put one on mine, works good.
Stealth_RT is offline
Old 11-19-2011 | 08:09 PM
  #694
very nice thanks. where did u get the red spacers looks awesome
psionic is offline
Old 11-20-2011 | 07:14 AM
  #695
Frank L's Avatar
You actually got yours to work? I tried multiple configurations and it would always bind so I ended up running the stock plastic setup.
They are m3 countersunk washers from amain. I am liking the red too.
Frank L is offline
Old 11-20-2011 | 03:35 PM
  #696
Seems to be working good so far. I used a non-nyloc nut and ground it down some so it would easily clear the servo and radio tray. I didn't put any washers under the arm on the servo, like it appears you did in those pics. Used plenty of locktight on the screw into the arm and the nut. I run on a VERY tight medium to high grip indoor track, so I need every little bit of steering I can get.
Old 11-20-2011 | 07:20 PM
  #697
teeforb's Avatar
Anyone selling theres?
teeforb is offline
Old 11-20-2011 | 07:30 PM
  #698
Frank L's Avatar
I will sell you mine for...
1 MILLLLLLION DOLLARS!!!
Frank L is offline
Old 11-20-2011 | 07:34 PM
  #699
teeforb's Avatar
Haahaha! Subtract $999,700. I'll take that shipped!
teeforb is offline
Old 11-21-2011 | 12:49 AM
  #700
brand new are only $550 just buy new.
Im ordering 2 of these later today.
Captainlip is offline
Old 11-21-2011 | 12:57 AM
  #701
teeforb's Avatar
I know, I know. I just spent way more then I should on this charger project I'm working on. It's the mother of all charger units. I'm talking a 2000w charging system. LOL.. So Im trying (not very good at it) not to spend too much more.
teeforb is offline
Old 11-21-2011 | 12:58 AM
  #702
teeforb's Avatar
Any upgrades necessary?
teeforb is offline
Old 11-21-2011 | 06:35 AM
  #703
Default Wow
Lucky for some. When you get yours sell one lol
muaythai is offline
Old 11-21-2011 | 08:20 AM
  #704
Aluminum front shock tower, for durability. Tuning parts like shock pistons, shock springs, webbed shock bladders, Option 1 and 2 akerman bars, 12 deg. caster blocks, and sway bars. Aluminum servo arm to replace the stock plastic one. Hard servo saver spring.
I haven't even used the low rear roll center toe in plate yet. Anything else you'd want would be bling or weight reduction, like hard anodized shock caps, Ti tie rods, LW hubs/wheel nuts, Ti upper shock mounts, etc.
Old 11-21-2011 | 09:02 AM
  #705
getting one for a friend.
