Serpent 811E Buggy Thread
#1441
I think you misunderstand me, the parallel circuit will supply the servo and separately the series circuit will supply the esc. if you were trying to connect both a series circuit and parallel to the esc then yes it would be bad.
#1442
Some updates....
The bracket itself.
Servo mounted
In the car for the looks
The esc and receiver test mounted
4 new holes...
Receiver in place
Everything in place...
Even if this mod did shave some weight and lowered the cg, the biggest advantage is in my eyes the new clean layout. And not to mention the shorter motor cables.
And yes, its tight between the front driveshaft and the steering link. But no touch.
The last piece of the bracket that is visible is for the transponder.
The bracket itself.
Servo mounted
4 new holes...
Receiver in place
#1444
Yes, its up to each person to do what ever he wants. The original 811BE is a very well constructed car. But in my eyes its a bit to complicated. And its not dangerous to modify things. Me myself is a very examining person. And is there things that brings things into better solutions, I do it directly.
Honestly, is there anyone that can give me one reason for me not to do this modification? And please, I dont wanna hear anything about "the dangerous" to modify something from its original and that it brings the value down.... there is no value in this and particularly after two laps at the local racetrack, 4 more holes in the chassie doesnt matter at all....
#1445
Let's call the packs A and B, so in the series connection A+ is connected to B-, A- to ESC- and B+ to ESC+. The parallel connection is A- to B- to S-, A+ to B+ to S+.
It means that B- is connected to both A+ and A-, so pack A is shorted.
Similarly A+ is connected to B- and B+, so pack B is shorted as well.
#1446
I'm away on business at the moment I can post pictures in a week. If you have an rx8 esc you can remove the red wire from the servo plug. Then run a new positive wire from the series jumper to your rx. The grounds are the same, this will pull voltage from one pack only to power your radio system.
#1447
#1448
The control you get from the rx8 is well worth any risk. It's very noticeable. I ran the MMM for a while in 1/8 e car and the MMP in the short course. Once I put the rx8 in they drove like different cars. I hadn't had any issues so far with the rx8 (^^^knock on wood^^^) I do cary a spare with me
#1450
#1451
OK, i"m convinced that the serpent is the best 1/8 scale buggy in the world! Doe's anyone have a current A-main coupon code? I'm ready to order it.
I have searched the forum but I have not been able to find a recent one thanks.
#1452
5Likes
