Serpent 811E Buggy Thread >
Like Tree5Likes
Old 10-30-2011 | 09:20 PM
  #541
porkchop's Avatar
i used good blue locktight and it be fine
porkchop is offline
Old 10-31-2011 | 01:06 AM
  #542
porkchop's Avatar
one serpent roller done
will be finshed off with
a team orion r8 pro esc team orion 1950 mr8 motor 2 5000 90c team orion packs. and a ko propo 30102 servo
cant wait to finsh it.
porkchop is offline
Old 10-31-2011 | 05:18 AM
  #543
Frank L's Avatar
Originally Posted by jk1152
Was looking at the new manual. Every where it totes captured pins but is the grub screw that grabs the diff coupler captured? If not anyone doing anything special? Like using red thread lock or heat shrink?
You mean the set screw on the pinion?
Just blue loctite and make sure you spray the screw and pinion coupler with some motor or nitro cleaner to get rid of the oil it comes packaged in.
Looking good porkchop
Frank L is offline
Old 10-31-2011 | 05:32 AM
  #544
UK.hardcore's Avatar
When you run it please tell the world how the Orion does.
UK.hardcore is offline
Old 10-31-2011 | 10:25 AM
  #545
bigjayjay1's Avatar
Guys found this servo horn order to see if its works will keep U guys posted, stock setup sucks stripped out on the 2nd run
http://www.ghhobby.com/proddetail.php?prod=5493&cat=44
bigjayjay1 is offline
Old 10-31-2011 | 10:29 AM
  #546
Randy_Pike's Avatar
Team Tekin
I don't want to hijack the thread for Tekin stuff. But losing a motor wire during a run is no bueno.
Any connection that can be eliminated is another possible failure point to eliminate as well.
Randy_Pike is offline
Old 10-31-2011 | 11:01 AM
  #547
bigjayjay1's Avatar
Did some track testing this weekend tried the box setup as a starting point WOW way off rear super wiggly made some changes per Franks advice its not a typical setup from a regular buggy but it works. Moved Rear camber UP, Hubs forward, increased front droop, stiffer rear springs.
Old 10-31-2011 | 03:31 PM
  #548
Maxxingout's Avatar
So ordering a extra set of stiffer serpent springs would be smart? I'm placing a order tomorrow so would be good to know. Also is it just the back end that would need it? I'm going to be running on a indoor med clay track.
Maxxingout is offline
Old 10-31-2011 | 03:47 PM
  #549
porkchop's Avatar
i would have on hand
orange and blue fronts
yellow rears and purple rears.
porkchop is offline
Old 10-31-2011 | 04:00 PM
  #550
Maxxingout's Avatar
Thanks porkchop, will do. I hope this isn't a dumb Q but does the kit come with a pinion? If not what would be a good starting point, mod 1 right?
Old 10-31-2011 | 04:30 PM
  #551
It comes with a 16T pinion. The correct gearing depends on what motor and battery setup you're using.
Stealth_RT is offline
Old 10-31-2011 | 05:41 PM
  #552
Maxxingout's Avatar
1900 with 2 2s hv batteries.
Old 10-31-2011 | 05:58 PM
  #553
jk1152's Avatar
Correct that's what I meant. I know with the s811 v1/v2 the way the pinion is secured to the coupler is a captured pin so just wanted to see if anyone had any issues with it yet.
jk1152 is offline
Old 10-31-2011 | 08:58 PM
  #554
Frank L's Avatar
Nice find
12-14 packs and no issues so far.
Where's the wood knock knock knock...
I'm running stock 16/46 on 5200 50c thunderpower and it's pleanty fast and temps in the 170's after 10 min runs. The fan is on in the esc though. I might even drop to a 15 tooth but the fan on in the esc tells me I'm already geared low.
Frank L is offline
Old 11-01-2011 | 08:41 AM
  #555
Frank L, I see in your set up sheet that you have used the 2mm off set wheel hex's. Do these widen the track by 2mm? Might be stupid question but just wondered.
Badger5 is offline
