Serpent 811E Buggy Thread
#3123
It fits, tight but fits. :-) Main thing is to drill a hole in the esc mount so the sensor wire can come out the center under the receiver. This makes the receiver wires come out on the side where the body will rub. Lay the wires flat then tape over them so they don't rub on the body.
#3124
I put a hole in the mount for the rx wire to thread out of, cut a notch in the bottom of that box to hide the bulk of wire underneath, then ran both esc and servo wires up through the holes to the rx box.
Also put some tape over the hole so the wire doesnt flap around and hit the driveshaft.
#3126
#3127
Mine is mounted the other way around, sensor wire outwards. I figured that I would rather replace a sensor wire than have to deal with the rx/switch wires.
I wonder if there are any right angle sensor wires. Maybe Ralph from TQ can source some. :-)
#3129
So where do I get bodies for my serpent?
http://www.absolutehobbyz.com/produc...oducts_id=7547
#3130
#3131
first thing to do before building this buggy is get rid of the screws that come with the kit. The screw head where you put the driver is not deep enough so they strip easy. Has nothing to do with the quality of driver.
#3132
#3134
I just can't wait to have mine in my hands and start deciding on electronics!
I am new to this 2.4 stuff, so to take it back a few post, If I am using a spektrum module in my M11 can I use an airtronics receiver, or do I need to use my tiny spektrum one? My local hobby shop definitely talked me into a savox servo and I don't want to run into any issues.
Is anyone outside of RCMayor running a hobbywing in here? Any pics of the install? Is 1900kv good for this car? Choices choices choices!!!
5Likes
