Serpent 811E Buggy Thread
#2461
I'm looking to purchase a dual lipo battery charger. I was curious what some of you are using and/or recommendations you may have. I read alot about the Hyperion Duo line of chargers, and they do get good reviews but I always like to know what else is out there.
#2462
It's in Union City (SF area). Let me know when you are coming and to what area. I'm sure we can find a race to get you into and that track is always open for practice.
#2463
I have 2 Hyperion duo chargers here. They can charge up to 15 amps per channel. Just make sure you have the power supply to support it. I use a much more 24 amp ps at the track and I have to limit each side to 8.5 amps or it shuts off. At home I have a Maxamps 24v brick ps. I don't remember how many amps it pushes But it will run 2 Hyperion duo charges pumping 15amps x4 into 4 seperate packs.
#2464
I'm using a Hyperion DUO3 0615i (2x 15A/180W) with a 12V/700W server power supply. I usually only charge at 1C though.
#2465
http://www.norcalhobbies.com/
#2468
#2469
Wasn't poking its just cause you have a good setup if you always charged at 1c it would be a waste some say don't charge above one C cause of lipo life so they don't.
#2470
Well, I have charged all the way up to 15A, but I puffed an Intellect 5600/50C pack right after I started doing that. It was about a year old at that point and I had just upped the motor in my SCTE around the same time. They were probably due. I have had really good results charging at 1-1.5C. Right now I have 2 packs for each car so I don't feel the need to charge any faster anyway.
#2471
The carbon straps will be available July 3rd. I will probably prepare the initial shipment during the holiday. I have 40 sets available and about 15 are spoken for.
Send an email to [email protected] with the exact words SERCARBON01 in the subject line and you will receive an instant link to paypal. Thanks for the interest. First class shipping is included, US orders only. I can ship overseas, will need to work directly with you for pricing on that option.
#2472
I have the venom duo. Its the exact same thing as the protek 610 duo except its cheaper, got mine for 110.00 and it has worked perfect so far. I also bought the protek super 20 power supply. Works great when charging my 2 5800 lipos at once
#2473
#2474
I was just swapping out a glitching rx8 and I went to test it, I was able to use wired batts (non bullet) with the CF batt straps. That's a big plus in my book as I tore up 4 wired thunderpower packs previously.
5Likes
