Like Tree5Likes
SC10 4x4 Thread
Old 12-30-2011 | 09:36 AM
  #13486
Evil Genius jr.'s Avatar
Ok, I will when I decide what to do (stay stock or go saddle).
Thanks!
Evil Genius jr. is offline
Old 12-30-2011 | 09:42 AM
  #13487
MantisWorx's Avatar
Thanks!
inline saddle is the way to go........
MantisWorx is offline
  #13488
CraigMBA's Avatar
Originally Posted by derbrylac
and lastly if it still steers around way too much over drive the front using the 19t pulley. hope this helps a little.
D
I disagree with this part. Over driving the front end will make the truck turn more center off, or at least when you get back on the power.
CraigMBA is offline
Old 12-30-2011 | 09:46 AM
  #13489
I know that it's just I already have a couple of stick packs and no saddle packs so...
Old 12-30-2011 | 09:48 AM
  #13490
R Doyel's Avatar
Thanks for the tips. I just checked the ride height, and it was super low in the rear......tons of scrapes on the back of the chassis. I leveled it out, I'll see if this does it....
R Doyel is offline
Old 12-30-2011 | 09:50 AM
  #13491
I had the exact opposite. mine was steering in alot and overdrives the front in made it push more and took away some of the steering on power. off power it still had lots of steering. so I up'd my front diff to take away more steering I guess each driver have different setups. this is just from my experience.
derbrylac is offline
Old 12-30-2011 | 09:52 AM
  #13492
Chad Smith's Avatar
I am in the same boat, but saddles are not that expensive. You can buy some saddles for 30 bucks.
Chad Smith is offline
Old 12-30-2011 | 09:55 AM
  #13493
testing this out from a known company and put over 20 batts and still going strong.
Old 12-30-2011 | 10:13 AM
  #13494
thebizz's Avatar
Originally Posted by mccune211
Just had the front diff on my rtr bind up one wheel spun the other didn't I turned little by hand now works fine anyone else have this prob or any idea y it did this
You might of chewed up the idle gear . take it apart and check it.
thebizz is offline
Old 12-30-2011 | 10:16 AM
  #13495
thebizz's Avatar
Marcus do run the b44 mount with the exotek chassis or the stock chassis
thebizz is offline
Old 12-30-2011 | 10:48 AM
  #13496
Steve737's Avatar
Alright, got my motor/esc choices down to two. Either the Castle Creastions 1415 or the Novak Ballistic. Recommendations between the two? Thanks.
Steve737 is offline
Old 12-30-2011 | 10:56 AM
  #13497
Anything but Novak
jimmer411 is offline
Old 12-30-2011 | 11:09 AM
  #13498
vito's Avatar
iam going with the new reedy 550 one
vito is offline
Old 12-30-2011 | 11:32 AM
  #13499
Chad Smith's Avatar
Most people run tekin why dont you want a tekin? The 1415 I would not suggest for this truck. That motor is designed for 3s and over lipos. It was designed for bashing. I am not saying that it will not work but not as well compared to a smaller can motor. With the 1415 being that big you are limited on gearing as well. With the stock spur I could only run up to a 19 thooth pinion. But coyoteslash runs that motor and a smaller spur so that he can run a bigger pinion to get the power that you need. Is there a reason you voted out tekin?
Old 12-30-2011 | 11:37 AM
  #13500
Mizchief's Avatar
I really liked the ballistic 550 combo, but either the esc or motor crapped out on me and got the "kick start" syndrome. So I swapped it for a mmp & tekin pro 4.
Mizchief is offline
