SC10 4x4 Thread
so when my antenna ripped out last week and was causing my car to cut out i bought a new reciever...the same one that was already in the car (TRS401ss 4ch reciever) i hooked everything up and when i turn my car on i hear everything start up, but when i turn on my remote nothing happens, no beeping noises or anything. is there some way that this new reciever needs to be synched to the remote or what do i need to do to get this running again?
http://lmgtfy.com/?q=Ace+RC+Cougar+PS3I+manual
for your radio model number, and "manual" found this:
http://mms.tiger.tw/upload/2009-7/2009782344
The info you are looking for is on Page 7
So I've ran into some other problems during the build. First, for some reason my rear turnbuckles are rubbing against my rear springs of the shocks?? Every time they compress you can hear the TB getting caught in the spring. Any suggestions on that? 2nd my spur gear seems to be rubing on the bottom part of the inner piece of the slipper case that connects to the motor mount. When I put the clutch together and tighten dwn the sliper nut to manual standards, it is very hard to rotate the wheels / shaft? I dk what I'm doing wrong here. Thanx for any advice.
12-13 you gotta check your temp after 5 min. I ran a 12 with a LRP 4.5 and 62 spur came off around 160'ish.
So plugging the battery will probably end up in a esc smoke show reminiscent to a Motley Crue concert.
You should have a physical copy of this manual in the box with your truck...
http://www.teamassociated.com/pdf/ca...dio_manual.pdf
Nice that AE doesn't include this in the related links for the RTR...
Oh, and given that the manual is EXACTLY the same as the Thunder Tiger one, just rebranded with AE all over it, tells me that AE doesn't actually make the radio gear...kind of like how losi uses Spektrum stuff. The info you need is still on page 7
the plug on the esc is a trxass plug i have a plug made up to hook it all up right.
5Likes
