Like Tree5Likes
SC10 4x4 Thread
Old 05-12-2011 | 08:02 PM
  #691
Cameron Kellogg's Avatar
Originally Posted by ktm11rider
Thanks Jstall.
So let me get this clear im sure its been covered but i dont wanna read every page. I am going to order some wheels and tires for this thing. The proline protrac and the new jconcepts wheels have the right offset for this truck???? I also heard the losi wheels fit but i will probally go with proline.
You can also use DE racing wheels for the Losi 4w too.
Cameron Kellogg is offline
  #692
ntrain42's Avatar
Originally Posted by Chuck 21
Sorry 7955TG is what I ment,heres a link to it just in case you haven't
heard of it...
http://www.amainhobbies.com/product_...-Digital-Servo
Considering I own 6 7955's yeah, I'd say I've heard of em. Along with 4 7954's, 4 7945's, 4 7940's and 1 5645MG(For my kid's basher) as well in my stable. Thats all I will buy and run are Hitec servos.
ntrain42 is offline
Old 05-12-2011 | 08:03 PM
  #693
RacerMike42's Avatar
Thumbs up
I have the Pro Line protrac wheels and they have the same offset as the stock wheels
RacerMike42 is offline
Old 05-12-2011 | 08:06 PM
  #694
jrusso3's Avatar
I picked my SC10 4x4 up yesterday afternoon, pulled an all nighter building it, sprayed the body this morning and just spent a few hours at the track. This truck is amazing. I've been away from a track for 20 years and my touch isn't there yet, but I can tell that this thing has serious potential, far beyond my current skills (need more track time). I opted for a Tekin RX8, LRP 5.5 550 motor and Savox 1258 servo, they all performed flawlessly. The steering geometry/sensitivity is outstanding. I've never built a kit that had a steering assembly this smooth and free. I've got a few adjustments to make, mostly to the ESC (punch), but all in all I couldn't be happier. Oh and this thing can take a serious beating. One of the guys commented "well I know one thing, that thing is tough".. Mainly because this truck was so good, it surprised me on more then one occasion, which lead to many an encounter with the walls, pipes, etc..
Oh and thanks to all who contributed to this thread with tips. The build was as smooth and fun as any I've ever done.
ps. My diffs were both just wet.. I cleaned them out and replaced with 5k.
jrusso3 is offline
Old 05-12-2011 | 08:07 PM
  #695
DirtDrop's Avatar
Originally Posted by Cameron Kellogg
So I am trying a 540 set up with a RS pro. I left out the removable tray and most of the rear bumper to make it as light as possible. Ready to run I am at 90.5 oz. So that gave me a different problem. Now that am running with the lighter radio gear I had to add 1.5oz. of weight way out on the left nerf bar to balance the chassis weight out (back to 92oz.). Seems using an RX8 speed control and the 550 motor would be the way to go to get the best power and balance.
I have a mmp and lrp x12 5.5 540. Motor and have more then enogh speed and low temps. I was 120 degrees after a 10mon race with a 18 tooth pinion and stock 48 pitch spur
DirtDrop is offline
Old 05-12-2011 | 08:08 PM
  #696
So you knew exactly what I ment from the begining Which I figured
you did.....
Chuck 21 is offline
Old 05-12-2011 | 08:31 PM
  #697
ktm11rider's Avatar
Tried to do the belt tension test the manual said and have it all at the stock settings but just running slow sitting on my stand it seems like there is alot of drag. Gear mesh is perfect i guess i could loosen the belt up some more. Just so hard to get it right when i have never even seen anything like this before
ktm11rider is offline
  #698
jks's Avatar
jks
Well just got my kit today and all I can say is very impressive. Cant wait to run it next week. It went together really smooth only issue I had was the rear shocks had to be bled,because they had too much oil in them. Also one of the metal threaded camber inserts in the shock tower wasn't threaded great on one hole so I will likely need a replacement from Associated. ---
jks is offline
Old 05-12-2011 | 08:51 PM
  #699
dagsom's Avatar
Just finished building mine!
I documented the build with photos. Check them out...
Gallery - @ strikerc.com
dagsom is offline
Old 05-12-2011 | 08:56 PM
  #700
A little bit of slop on the belt is fine... better even. The heli guys would always say that you should be able to pinch the belt and it should come together (at about several inches from the pulley).
BoneDoc is offline
Old 05-12-2011 | 09:18 PM
  #701
ktm11rider's Avatar
ok cool ill just run it and see. It much be my motor that seems to have alot of drag when i roll it and run the throttle at low speeds. Worries me about temps but untill i get a chance to run it on a track idk.
Old 05-12-2011 | 09:25 PM
  #702
ntrain42's Avatar
you did.....
Yeah but the serov model # kinda stumped me. Im waiting for those new BL servos to be released from Hitec y'know.
ntrain42 is offline
Old 05-12-2011 | 09:26 PM
  #703
first off, sorry if this has been posted already..secondly.the losi scte sway bar's will fit...with some slight but easy modification's
here's some pics
the screws in the chassis hold in the sway bars just fine....and all of the hardware is from the losi scte sway bar kit....only thing i had to do was drill out the ball joint that goes into the a-arm in order to fit a 2.5mm button head through it...
hootie7159 is offline
Old 05-12-2011 | 09:55 PM
  #704
Jstall7543's Avatar
here's some pics
Attachment 751577
Attachment 751578
Attachment 751579
Attachment 751580
Very innovative, but I don't thing that's going to function correctly, the washers are making it impossible for the proper bar movement. IMO.
Jstall7543 is offline
Old 05-12-2011 | 10:00 PM
  #705
So I cruised mine around the dw tonight, all in all it's pretty smooth, the steering only took 2clicks of trim. Clicker will take some getting used to.
I'm not thrilled that you can't get a straight shot at the lower motor screw...
All in all it's a good kit, I'm sure it will have a ton of potential too.
I'm just waiting on some goosebumps as I didn't want to waist the stock wheels by glueing the Junkers on them.
I went with a mamba monster max, with the 1410 motor. A CC 10a external bec. And I went with a 7965 for the servo. I started the gearing at 17 and 62 and it feels slow will probably end up at around 20-62 depending on temps..
Anyone else feel it sits too tal with the stock springs backed all the way off?
Dragrcr is offline
