SC10 4x4 Thread
#5236
I think he meant 5 - 10 minutes.... unless his track has an hour between heats and he never marshalls anyone elses races....
At my track, if you aren't racing, you are marshalling....2-5 minutes between races, then a 20 minute break between rounds...
After I race, I have to run, get my truck off the track, get the old battery on the charger, get back out on the race track to marshal.... then once the round is done, I have 20 minutes to get my truck ready for the next round...sorry, not enough time to check camber, ride height, clean the truck, AND change a diff...assuming you have one pre-built with different oil...
#5237
T-birdjunkie is more than welcome here. He's been more than helpful with information and helps out where ever he can. Just because you find his 3rd person thing "annoying" doesn't mean you can tell him to stay away.
#5238
Suspended
LMFAO, I contribute more then you could ever dream to, You see, i help people outside of the interwebnet world you live in.
Doesnt change the fact that you come off as a complete toolbag with the way you type, and portray yourself online.
Im betting you live in your mothers basement, and you've never experienced a woman
#5240
I never said his posts aren't helpful, they are annoying is what I said. He thinks he is smarter and more important and the only one who matters around here which isn't the point of the forum. The point of the forum is to help.
#5242
#5243
Hey guys Im finally getting close to getting my truck dialed in on a tight indoor clay track but still have some work to do.
One problem Im having is rolling over in corners/top heavy/traxxas type feeling. Should I adjust roll center by adding washers under the balls? Anyone know of a way to stop this from happening?
Another problem is when I overshoot a jump and the truck lands in the flat it wants to flip over. Anyone know of any fixes for this situation that wont mess with my setup too much?
I prefer the barcodes. He can't hang with me so like always the right tire for the track is crucial! My setup is all stock except for shocks mounted wide on the arms.
#5244
#5246
Hey guys I'm new here but not to r/c. I just picked this truck up new at the lhs. Good build. I have a question about the diff/ diff fluid. It comes pre built and I saw the warnings on page 1 about some coming without enough fluid from the factory. I cracked mine open to check it out and there definitely was fluid in the case. Here are my questions
Can you use too much diff fluid?
Can you wreck th diff if you mix two types of fluid ? Ie. I'm not sue what the factory used and I want to top it off.
Eric
Eric
#5247
Eric
Eric
#5249
Eric you'll want to open up the diffs, there are 4 screws. the factory hardly puts any fluid at all.
You'll want to put enough fluid until the pins in the middle are just covered in the middle.
Most people are running 30k weight fluid in the front and 3-5k fluid in the rear.
The thicker weight kinda calms the front end down and allows the front wheels to pull you out of corners better.
5Likes
