SC10 4x4 Thread
#376
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Same body as the 2W Sc-10, not sure how thick , but its a durable shell ...
Kits tires look good for bashing on asphalt & base ball diamonds ...
#377
Hey guys I hope the building is going better for you than me. I built mine in about 6.5 hours. I am using a tekin 5.5 sc4x. I matched it with a 14t instead of a 13t pinion that the manual called for. my motor is getting a little hot and that is after 4 minutes running. What bother me most it that when i flat out accelerate the motor acts like it has a rev limiter on it and it wont go fast at all. When i accelerate smoothly it will hit a normal top speed. Iam using the VXL ESC out of a slash 4x4. If any one can give me some insight I would appreciate it.
#378
Only got the servo installed on mine last night before the wife cut the power to my workshop so I had to go to bed...
Savox 1267MG - Servo wire is way too short. Needs an extension.
Also, the stress relief rubber on the side of the servo (where the wire comes out) binds a bit on the servo mount.
I was thinking of trimming it...
#379
Tension seems good but I will check it. Do you recommend the 13t pinion cuz I was under the impression that going up in the teeth would keep the engine cooler. Thanks a bunch bro!
#380
#389
does anyone needed a servo extension cord or Savox servos?
And anyone already managed to fit a tekin rx8 any mods needed
#390
I don't understand why belt tension is considered a "setup" Seems like there should only be one correct tension and should not have much effect on car otherwise except a bit more friction to the front end.
Can someone elaborate on why there are different belt tension settings shown on the setup sheets?
