Like Tree5Likes
SC10 4x4 Thread
Old 10-23-2012 | 10:40 AM
  #30691
keddy's Avatar
Originally Posted by Cain
Keddy's setup for those of us photobucket challenged
How is bottoming out with this oil setup?
Hasn't been an issue for me. Though, I live by " you cant make power if the wheels arent on the ground" so I keep my ramp to ramp transitions as smooth as possible and my ramp to flats as low as possible.
I find the faster acting suspension keeps the tires on the ground better,
keddy is offline
Old 10-23-2012 | 10:44 AM
  #30692
Cain's Avatar
Tech Legend
cool. You try the Center Diff at all?
Will add this setup to my binder
Cain is offline
Old 10-23-2012 | 10:51 AM
  #30693
keddy's Avatar
I did many times. I've tried everything in the centre slip/diff department.
I found it unreliable. My best most consistent days were with the exo locked hub and garo for the rear.
Here's the results for the last race. Click over to the second page for 4x4 shortcourse A-main.
We're only a few seconds from ebuggy
https://docs.google.com/file/d/0B-tl.../preview?pli=1
This is the track I run on. Shot this on a rainy day.
keddy is offline
Old 10-23-2012 | 11:15 AM
  #30694
heavyjeffd's Avatar
Trying to get more info on that Prolite4x4. Since it's shaft drive (and many of us have been dying for such), I'm trying to find it what parts it's compatible with, etc.
Time to buy one and hop it up.
heavyjeffd is offline
Old 10-23-2012 | 11:56 AM
  #30695
TXRC8racer's Avatar
Ok battery preference stick pack or saddle pack?
TXRC8racer is offline
Old 10-23-2012 | 12:09 PM
  #30696
heavyjeffd's Avatar
Depends on the setup you like. I've only run stick so far, I'm going to try saddle.
  #30697
Cain's Avatar
Tech Legend
Probably anything that fits the Thunder Tiger Sparrow Hawk line is worth at least a look as it may be compatible.
Saddle packs in center chassis configuration. Though, a stick pack down the middle could be killer. Maybe exotek will make a chassis that can do that?
Cain is offline
Old 10-23-2012 | 12:13 PM
  #30698
MantisWorx's Avatar
Well said, you are one with your truck!
MantisWorx is offline
Old 10-23-2012 | 12:50 PM
  #30699
TXRC8racer's Avatar
I have the RTR version and just bought the FT kit that AE sale's and I have the option to run stick pack or saddle packs.
So your saying run saddle packs in the center?
Old 10-23-2012 | 12:55 PM
  #30700
TXRC8racer's Avatar
Or should I say center or cradle form.. Or is it just play around for best setup?
Is there an advantage to saddle pack batteries than stick packs? I'm thinking about the Orion saddle 5500mah 90c battery for my sc10
Old 10-23-2012 | 01:03 PM
  #30701
Cain's Avatar
Tech Legend
Me personally I found that the car felt better around the track with the saddle packs down the middle. Disadvantage, if you have a track that can be brutal on runtime, you may find the benefits get outweighed because of this. You can however look into a center stick pack setup as well.
Anyone know the difference between part # 91174 and #91174P
descriptions appear to be the same but one is more expensive?
Cain is offline
Old 10-23-2012 | 04:12 PM
  #30702
Nice times.. Your not just beating the other guys your crushing them!
Track looks like much fun. Glad to see not everyone is struggling with this truck.
Oil Jockey is offline
Old 10-23-2012 | 05:17 PM
  #30703
Looks like a good set up but if you got a heavy trigger finger going to be all over the place
9turn is offline
Old 10-23-2012 | 05:39 PM
  #30704
keddy's Avatar
Exactly. You've got to drive the truck for what it is. I never understood why people use "nitro finger" for driving electrics. With a high end ESC/Motor youve got sooo much throttle control, but I never see anyone use it.
I run 10min mains on 5000mah saddle packs, and put 4000-4100mah back into them. It's all about being efficeint with this truck.
keddy is offline
Old 10-23-2012 | 05:41 PM
  #30705
keddy's Avatar
Originally Posted by Wild Cherry
Now your a grammar nazi with cut down pics ?
It's funny you're calling someone a Nazi, being so closed minded and all.....
keddy is offline
