Like Tree5Likes
SC10 4x4 Thread
Old 09-27-2012 | 01:57 PM
  #29941
CraigMBA's Avatar
Originally Posted by Cain
thanks, will just pick up the lightened one, give it a tear down and see if there is any other damage.
You want the one with the 80 in the part number.
I'd never run the lightened one in this truck.
CraigMBA is offline
Old 09-27-2012 | 02:01 PM
  #29942
I've been running the lightweight front and rear ones since last August. Running V1 and V2 Center diff, and the VTS
No problems. Just fyi
SC Shaun is offline
Old 09-27-2012 | 02:12 PM
  #29943
BentKa's Avatar
Why not ?!?
If you're not going to run the coupled slipper hub why wouldn't you want the lighter option top shaft ?!?
I'v been running it in mine front and rear for more than a year now on high bite indoor clay and outdoor astro turf........not a single issue so far
Just recently replaced it with a new one during a total rebuild......not necessary at all as it showed no signs of wear or tweak.......but felt obligated to since I had been running it for over a year
Bent
BentKa is offline
Old 09-27-2012 | 02:17 PM
  #29944
Default Traction Rolling Bad
While racing last night, I was traction rolling real bad getting into the corners. My track is high bite wet clay. I'm running ProLine Suburbs MC compound on JConcepts Hazard wheels. I"m running the 8MM mod in the rear. I have 2.0 sway bars front and rear. 27.5wt blue front springs in the front / 32.5wt blue front springs in the rear. RCShox V2 center diff with 8 pins. 25MM ride height all around.
Any suggestions guys? Remove the 8MM Mod for indoor high bite track? Change springs?
I didn't have these issue at all while outdoors with truck setup the same way.
Snafujg is offline
Old 09-27-2012 | 02:36 PM
  #29945
CraigMBA's Avatar
If you don't plan on ever running the coupled slipper hub, I guess it's okay...but I can't see how having this particular part be lightened makes the truck perform better or be more durable ( in a really meaningful way compared to the effort it takes to change it).
IMO.
CraigMBA is offline
Old 09-27-2012 | 02:37 PM
  #29946
CraigMBA's Avatar
Lower the ride height.
CraigMBA is offline
Old 09-27-2012 | 03:00 PM
  #29947
IMO.
This is true.
SC Shaun is offline
Old 09-27-2012 | 04:40 PM
  #29948
FRONTI3R's Avatar
What's your camber set at? For that type of track I would try the yellow springs in the front. and for the rear put White front springs.
I haven't tried the the 8mm mod yet. I would suggest 6 pins in the Center Diff.
FRONTI3R is offline
Old 09-27-2012 | 05:03 PM
  #29949
JEFFs SC10's Avatar
go to 23-24 mm ride height and increase camber to like 1.5 all around.
JEFFs SC10 is offline
Old 09-27-2012 | 05:53 PM
  #29950
Now that I'm home, I checked camber and found that I'm at -1.5 all the way around. Also, ride height is about 23 in the front and 25 in the back. So I will lower the back. Blue Sway bars front and back.
Should I also try a smaller sway bar?
Snafujg is offline
  #29951
Positive 1.5?
Snafujg is offline
Old 09-27-2012 | 05:55 PM
  #29952
JEFFs SC10's Avatar
NEGATIVE! do you have a camber guage?
Old 09-27-2012 | 06:32 PM
  #29953
Positive camber would be hilaaaaaaaarious.
SC Shaun is offline
Old 09-27-2012 | 06:55 PM
  #29954
fq06's Avatar
Looks like he is saying negative (-1.5) and to know that number I'm going out on a limb to say he has a gauge
EDIT: I see in snafu's post it was originally 1.5 camber.
For sure drop the rear, a taller ride height will make the chassis roll more putting more bite in the rear tires. Dropping it, just like a ricer Honda will reduce chassis roll and the side bite in the tires.
Increasing negative camber will also keep the outside of the tire from biting in as hard if lower height in the rear doesn't help. But -1.5 should be sufficient, play with ride height, thicker sway bar, thicker oil, roll center... many different ways to reduce roll in the truck. Add stiffer spring rate to that list courtesy of Ryan.
To flash back a page or two, -1.5 with a camber gauge may not be -1.5 as well
fq06 is offline
Old 09-27-2012 | 07:00 PM
  #29955
fq06's Avatar
Flash back to 70's Baja bugs
fq06 is offline
