Like Tree5Likes
SC10 4x4 Thread
Old 09-04-2012 | 09:32 AM
  #29206
Wild Cherry's Avatar
Tech Legend
Originally Posted by fq06
So inside on the shock tower and middle on the hub?
Inside hole on C hub with 8mm & either stud hole on tower depending on what set-up you are using.
old guy
lower ft end & rear to 24mm .
lighter oil for Ft shock
Wild Cherry is offline
Old 09-04-2012 | 09:33 AM
  #29207
fq06's Avatar
Oldguydust,
Try 6 pins in the diff then 8 and see what gets what your looking for. Easy adjustment to make, play around with it.
More pins is like a thicker diff fluid in a center gear diff.
Activated clicker will help with turn in, but as soon as you get on the gas and you are having understeer issues you are in 4wd and the clicker is not active.
Also try equal out the ride height, more weight on the front with 25/25 vs 26/25.
fq06 is offline
Old 09-04-2012 | 09:36 AM
  #29208
fq06's Avatar
If the setup that you are using is the outer hole on the hub then that would add roll and traction compared to the base setup of middle hole right? And then you are taking some away lowering the ball stud?
fq06 is offline
Old 09-04-2012 | 09:37 AM
  #29209
Cain's Avatar
Tech Legend
Originally Posted by CraigMBA
You should read Cameron's post on the subject.
http://www.rctech.net/forum/10640989-post22028.html
Lord I miss him in this thread.
8mm mod raises the outside & inside stud's to reduce traction & roll, so if you lower the inside stud with 8mm you will feel more traction .
Even more traction using standard hub & camber ....
Thanks to both. Figured it was like that, but wanted to make sure there wasn't something I was missing. Based on what I have right now (lowest stud position, no 8mm mod), going to see about lengthening the link.
Heck, I wonder if maybe a lengthening link "mod" of sorts could be beneficial lol
Cain is offline
Old 09-04-2012 | 09:39 AM
  #29210
Wildcat1971's Avatar
I found that belt tension and tire tuning are big. For me a losser belt and lower bite tires up front made it night and day. Personally I need a chassis stiffener. Tk make tne belt tension more consistent. I am poor atm, so it will have to wait
Wildcat1971 is offline
Old 09-04-2012 | 09:40 AM
  #29211
MD's Avatar
MD
This might've been posted since I"m new to this forum I'm not sure, but for a high bite track you may want too look at one of Kinwald's set ups.
http://www.teamassociated.com/pdf/ca...d_Standard.pdf
MD is offline
  #29212
vito's Avatar
it was set by the book had to back it off some
vito is offline
Old 09-04-2012 | 09:41 AM
  #29213
OldGuydust's Avatar
Thx. Wc and Fq.... Nothing like tinkering and testing!
Btw.. I love my ae rigs!!!!!!!
OldGuydust is offline
Old 09-04-2012 | 09:44 AM
  #29214
Cain's Avatar
Tech Legend
Originally Posted by OldGuydust
Very interesting..... Currently my issue is understeer.
Here are my facts..
High bite clay
Clicker locked
8mm mod
Yellow front springs, 35w, no reb.
Blue rear springs, 27.5w, no reb.
V2 center diff, 4pins
26mm fr ride height
25mm rear ride height
I'm thinkin about lowering 1mm around and loosening clicker...?
After that I may drop inner rear ball studs 2mm...
Ideas??
what are you front and rear diff fluid configurations? For high bite (it was carpet), I liked 7K front and I believe 5K rear, albeit , was a clutch basket but from what I am initially thinking for this winter, would still do the same with the center diff but more pins of course than I do right now (4)
Cain is offline
Old 09-04-2012 | 09:59 AM
  #29215
Here are my facts..
High bite clay
Clicker locked
8mm mod
26mm fr ride height
Ideas??
5k front, 5k rear (7k front is fine too)
6 pins
yellow rear spring
24mm height
SC Shaun is offline
Old 09-04-2012 | 10:03 AM
  #29216
Question. Would running the sc 4x4 at 1/3 t 1/2 speed for the entire race cause any heay issues? Wanna let mykd run it. But she cant drive it with full powef
Old 09-04-2012 | 10:15 AM
  #29217
CraigMBA's Avatar
Here are my facts..
High bite clay
Clicker locked
8mm mod
26mm fr ride height
Ideas??
I think your ride height is way too high. I never run more than 24 unless the track looks like it was carpet bombed by the USAF.
Plus it's easy.
CraigMBA is offline
Old 09-04-2012 | 10:21 AM
  #29218
fq06's Avatar
Good point Cain & Shaun... diff fluid.
First tried 7/5 with the C-Diff then tried 5/5 and it gives me what I'm looking for. Odd occasion I get to an outdoor track I will play with pin count, 6 pins baseline for indoor.
1:8 buggy fluid change for a new track, no big deal. Fluid change in this thing... OMG.
Anyone else see the pizza banner at the bottom of the page? Mmm I'm getting hungry
fq06 is offline
Old 09-04-2012 | 10:42 AM
  #29219
Cain's Avatar
Tech Legend
Personally I don't think so. The time when I have seen people get the motors too hot is when they have it pegged at near WOT as far as the motor is concerned around the track for the race versus gearing it correctly.
Watch it for sure though.
What gauge is everyone using for ride height that doesn't cost more than a pizza
Cain is offline
Old 09-04-2012 | 10:50 AM
  #29220
ilanstylz's Avatar
I use the losi one:
http://compare.ebay.com/like/4003170..._lwgsi=y&cbt=y
ilanstylz is offline
