SC10 4x4 Thread
Personally I don't think so. The time when I have seen people get the motors too hot is when they have it pegged at near WOT as far as the motor is concerned around the track for the race versus gearing it correctly.
Watch it for sure though.
What gauge is everyone using for ride height that doesn't cost more than a pizza
Gotta get rid of some stuff, anyone need some spare transmissions and wheels/tires:
http://www.rctech.net/forum/r-c-item...nsmission.html
ride height
http://www.stormerhobbies.com/cgi-bi...s&pn=LOSA99173
camber
http://www.stormerhobbies.com/cgi-bi...s&pn=LOSA99172
when i had a b4 i ran tlr springs and pistons.
waiting for indoor to pickup another fresh one tho.
May try the mod someday for the outdoor track, but haven't felt a need to change where I'm at with my tune, thanx.
I use my old huddy 1/10 onroad station on my truck for camber and it's way more accurate than sticking something up against the side of a tire that is not the same all around and the wobble of the front end amplified with the larger circumference that your measuring from.
A friend used his camber tool and for the hell of it I threw it on the huddy and he was off by about .5° front and .3° rear and none of the measurements were to the mm.
The 1/8 scale one will be tall enough to clear the shock tower too so you can get your steering centered, set toe out and the steering throw balanced perfectly
You will tell the difference with a correctly set chassis.
My 1/10 one is not tall enough to clear the tower
almost embarrassed to say it, but never used one. I have had it sitting in the box for some time now, just haven't found the need or time on my 1/8 buggy, and I heard there may be some clearance issues on the sc10 4x4. Will give it a try though.
Slide the truck back and forth then push down on car many times throughout your adjustments.
5Likes
but I will give the Losi ride height one a try.
