SC10 4x4 Thread
#2881
I personaly have build THREE of these SC10 4x4's for myself and buddies... without a single issue of any kind. I've also raced mine a couple times and we raced on the weekend again with no issues.
#2882
The are ready to go
“Trinidad” SC Wheels for Team Associated SC10 4x4
Named after a rugged valley section of the prestigious Baja 500 and 1000 desert races, DE Racing brings you the "Trinidad" SC wheel. The most detailed and scale wheel available for your short course RC.
DE Racing specializes in highly innovative performance products and our wheels are no exception. Manufactured in the U.S.A. from the finest possible materials and utilizing an advanced ribbing design, "Trinidad" wheels offer strength and durability while still remaining lightweight. Intended for the highest levels of competition, they also feature ROAR legal widths and bead diameters in a one piece glue-able design.
Wheels Feature:
• True OEM fit
• Realistic scale appearance
• Advanced ribbing design for strength and durability
• Roar legal widths and 2.2 / 3.0 diameters
• Made in the U.S.A.
Fits:
Team Associated SC10 RS
Team Associated SC10 with 12mm Hex Adapters
Traxxas Slash 2wd with wide-track suspension kits
P/N:
DER-SCT-A4B BLACK
DER-SCT-A4S SILVER
DER-SCT-A4W WHITE
The will be ready soon in white and silver, but for now its black.
They can be found here: http://www.deracing.net/store/index....ry&path=62_140
Wheels Feature:
• True OEM fit
Fits:
P/N:
DER-SCT-A4B BLACK
DER-SCT-A4S SILVER
DER-SCT-A4W WHITE
#2883
On second thought....
There is one way the CvD pin could come out , a loose wheel nut perhaps ?
Seen some use other brand wheels & their fit is not the same as the Ae so the lock nut does not fit correctly and comes loose when on the track...
#2884
It just sounds like a faulty part.
#2885
i agree faulty part . call AE they will take care of you .. might take a while tho . tower has the inner axles in stock if you cant wait for AE .
#2888
#2890
Has anyone noticed the out drives getting sloppy in the diff gear housing. My cups are starting to develop a lot of movement. The o-rings seem to be sealing the fluid still but this stuff is so thick it take weeks to leak out anyway.
Any thoughts on this? Maybe AE did not grease the shafts when assembling the diffs?
#2891
I am about to buy a SC10 4x4 and was wondering what the best motor esc combo would be. I usually prefer to run tekin since its the brand I know but I am open to other brands. I will be running it on a large 1/8 scale clay track and also a small 1/10 scale loose dirt track. I have been trying to read through all the posts in this thread but still unsure which motor\esc to get.
thanks
thanks
#2892
thanks
thanks
#2893
#2894
#2895
thanks
thanks
5Likes
