Like Tree5Likes
SC10 4x4 Thread
Old 06-09-2011 | 07:44 AM
  #3031
Originally Posted by Chris Jarosz
91123- Front Swaybar Set
91124- Rear Swaybar Set
91126- Swaybar Hardware
You don't need the swaybar hardware if you get the swaybar sets. That is just extra hardware if you need it.
anyone know where I can place an order for these. I found the front ones on tower hobbies but I cant find the rear or the hardware.
thanks
Cyric is offline
Old 06-09-2011 | 07:47 AM
  #3032
kromesoldier's Avatar
Originally Posted by Shark413
I don't see how people are getting an allen wrench in there, but I hear it can be done. I prefer a good hex driver and it took all of 15 mins to do the mod. Whatever works for you is cool.
i get an allen wrench in there just fine. got a 1415 in it. change the pinion several times that way. in fact. i havent taken the motor out since i installed it. if you turn the screw to about 2 o clock you can slide the allen wrench right in there.
kromesoldier is offline
Old 06-09-2011 | 07:58 AM
  #3033
BlueGlowBoy's Avatar
Originally Posted by murky123
anybody ?
Check with FastEddyBearings.com
I gave him the dimensions and quantities for the set and they should have a kit put together as soon as they can get some of the 3mm bearings. They have all the other bearings.
BlueGlowBoy is offline
Old 06-09-2011 | 08:21 AM
  #3034
Originally Posted by latenight
Can some of you 550 guys post your motor temps after 20 minutes of run time without a fan on a 20c 5ah lipo?
Thanks in advance
Can't give you exactly what you are looking for, as I was running 60C 5500mah packs.
Ambient temps: approx 20 C (68 F) No wind.
"Track" Conditions: 2-3" tall grass (school playground)
"Track" layout: 60' main straight with a large sweeper leading into it, 2 hairpins, small technical section. Lots of hard accelleration, as well as a decent high speed section. 1 small jump where the trucks get about 12-16" of air.
truck setup: 14/62. Clicker set loose. 3k diffs front and back. Tekin 5.5T 550, RX8.
No matter what I did, the ESC never went above 1 temperature light and the motor maxxed at 116 F. Ran through 2 packs down to LVC set at 3.65v
Old 06-09-2011 | 08:43 AM
  #3035
1415 castle. 93/25 gears. 5000 50 c battery
I ran a 10 minute main and was at 105 degrees
Large 1/8 scale track.
Old 06-09-2011 | 09:28 AM
  #3036
MarqueeRc's Avatar
How do you like the 1415 setup on this truck...Does it perform well on 2s???Are you using the castle mmp sct esc??Any mods done to get it in the truck seated properly??Are you happy with this setup?
MarqueeRc is offline
Old 06-09-2011 | 09:40 AM
  #3037
Great motor on 2s. Maintains low temps. Im not using any boost. Lots and lots of low end torque. I can follow the same line as the 1/8 scale buggies on a long track. You gotta adjust your nuetral a bit because the motor has 4 poles istead of two. Give ya a little neutral brake if ha don't adjust. But look. I'm running 93/25 and I have plenty of power to make a last minute leap of fate.
Yes I have the mmp sct installed. No bec issues. I can't wait to get more shock springs so I can tune the truck a bit more. To install. I had to do some light sanding in the corner of the rear chassis. I have full adjustment on the motor plate. It runs very well on the 2s pack IMO.
Old 06-09-2011 | 09:51 AM
  #3038
Is 3.65 the exact setting you are using in the custom cutoff?
If you are, understand that value is an 'absolute' value and not a per-cell value. If you want a cutoff of 3.65 volts per cell on a 2 cell pack you would need to set the custom voltage cutoff on the RX8 to 7.3 volts.
Krio is offline
Old 06-09-2011 | 09:52 AM
  #3039
I love my SC10 4x4 but one thing is a real pain, changing or adjusting the pinion. It basically requires you to pull the entire motor out. So I decided to do what AE should have done for us. I drilled a hole thru the bottom of the chassis that lines up with the pinions grub screw. So now I can stick a wrench in the hole and loosen the pinion grub screw to adjust or remove the pinion. I used a small foam wedge to seal the hole from the inside. See my post on RCShortcourse. http://www.rcshortcourse.com/forum/s...774#post189774 for the gory details (it's a long post and I didn't want to clutter this thread).
With a small hole in the bottom of the chassis I can insert a 2mm hex driver and loosen the pinion grub screw without removing the entire motor.
Small foam wedge seals the hole from inside.
Here is the bottom of the chassis. The hole is where the rear chassis slopes so it won't snag on anything and is small enough to not compromise the strength of the chassis.
I was going to do this as well but didn't want to still then add a screw for access so itrimmed the belt housing so now its a clean look and I can get direct access to the screw just haver to remove gear and belt cover
Mike_Shepard is offline
Old 06-09-2011 | 10:23 AM
  #3040
What are you guys using to plug the hole that allows dirt to get into the gearbox through the motor mount screw slots? This wasn't the best design.
killerguppy is offline
Old 06-09-2011 | 11:57 AM
  #3041
JayL's Avatar
R/C Tech Elite Member
with my 550 motor the slots are covered, with 540 they show so I strapping tape inside belt area
JayL is offline
Old 06-09-2011 | 12:14 PM
  #3042
Default greasing bearings
i dont know if this applies the same in the rc world, but i am also an avid downhill longboarder.
to make my bearings last longer before cleaning, make them more rust proof, and dirt resistant, i would grease them. this does make them slower vs oil, but it's not noticable after a few warmup runs to get the grease hot.
is it safe to grease my bearings for rc trucks as well?
i ask this because several people are looking at aftermarket bearings so soon.
shadoflame is offline
Old 06-09-2011 | 12:19 PM
  #3043
Numburn's Avatar
Thanks CraigV for compiling all this information on the first page and keeping this up to date!
Is there a similar thread for the 2wd SC10? I haven't been able to find one.
Numburn is offline
Old 06-09-2011 | 12:49 PM
  #3044
AccessRacer's Avatar
RC SCREWZ for bearings and screw kits
http://www.rcscrewz.com/advanced_sea...074f1e&x=0&y=0
AccessRacer is offline
Old 06-09-2011 | 02:00 PM
  #3045
JEFFs SC10's Avatar
Can someone give me dimensions and/or a picture of the swaybars that they bent up? Decided to make my own.
JEFFs SC10 is offline
