-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   SC10 4x4 Thread (https://www.rctech.net/forum/electric-off-road/511493-sc10-4x4-thread.html)
JEFFs SC10 07-20-2012 11:41 PM
wow that's a nice but very technical track, wish you the best of luck. I think 16 is too much, unless you want to slowly roll up to a jump then goose it and hope to get over a triple. It's up to you, I'd rather have something a little tamer and smoother but that's just me. Is that a high grip track?
ABN Hoosier 07-20-2012 11:49 PM
It is a clay mix. When the sun is out it dries up and gets a bit loamy (qualifiers). They water it about every 3rd heat race. When the sun goes down (mains) it is better.
JEFFs SC10 07-20-2012 11:52 PM
that's cool man, I would do double single on that big triple, you'll be more consistent. Should be fun!
ABN Hoosier 07-21-2012 12:08 AM
Yeah, I plan to do double double single on it. EVERYONE at that track, I'd say 10-12 guys run the Losi SCT. I think maybe 3 of us run the SC10 4x4....
Maddog94 07-21-2012 04:59 AM
Guys,
I keep seing on the setup sheets that you can adjust the wheelbase (near the rear suspension section on the top right of the setup sheet).
How is this done? I have no idea!
Wildcat1971 07-21-2012 06:29 AM
Originally Posted by Maddog94 (Post 10999715)
Guys,
spacers on the rear rubs.
ilanstylz 07-21-2012 06:31 AM
Guys,
On your rear wheel where the cva/axle attaches to the a-arm with the hinge pin there are spacers that go on the inside. To shorten the wheelbase you put both spacers in the back, for medium you put each spacer on both sides, and to lengthen the wheelbase you put both spacers in the front...........
Generally you shorten it for better steering and lengthen it for more stability at higher speeds.
drolmaeye 07-21-2012 06:39 AM
Originally Posted by itchy b (Post 10998984)
I do have one of these Ace servos spare i can use which should fit the bill then :)
Same servo horn too :D
http://www.servodatabase.com/servo/ace-rc/ds1015
Will keep the savox ones for the smaller cars then :)
I use the same in my truck (the Associated version, I think it's labeled the XP DS1015). They work well. I bought a servo extension when I got the servo, but ended up not needing to use it; mine reached the receiver just fine.
itchy b 07-21-2012 06:57 AM
Good to know :)
Will install it tomorrow then, and set everything else up ready to fire up :)
fq06 07-21-2012 07:10 AM
Originally Posted by JEFFs SC10 (Post 10999358)
Replaced Savox with Hitec 7955, my brownout and glitch problems went away. I run a rx8 and pro 4 and that savox drained the bec.
Me too, rx8 and It was useless... couldn't drive 5 seconds without a brown out.
Fine with external bec now, I didn't think I would have to go there with the rx8's 5a bec... but I did.
Evil Genius jr. 07-21-2012 07:59 AM
Well finally weighed my truck.
2800g exactly. sound right?
JEFFs SC10 07-21-2012 09:56 AM
Want to test out the new changes I made but it is 150 f'n degrees outside and I don't feel like dealing with it. <<getting old>>
SOuthernFRIED 07-21-2012 10:13 AM
150?? Hell cain't be more than a 137 out!!!:lol:
Wildcat1971 07-21-2012 10:22 AM
Did AE send any drivers to the Hotrod Hobbies shootout for the sc4x4 class?
Wild Cherry 07-21-2012 10:34 AM
Hot Rod Shoot OUT
www.liverc.com :cool:
here in Tacoma its 64 degrees & loving it ....
